Manual vs auto exhaust - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-08-2013, 12:54 PM Thread Starter
Question Manual vs auto exhaust
So I have a chance to get a turbo back 5in exhaust with 4in down pipe for $200. Possible problem is it says automatic tranny only and I have a manual. Whats the difference in the exhaust? Can I make it fit fairly easily?
Nightwolf881030 is offline
post #2 of 11 Old 03-08-2013, 04:23 PM Thread Starter
Looking at an auto they look the same to me and if some companies sell exhaust that does not specify auto or manual then the differences should be minimal I would think. Any one have experience with this?
post #3 of 11 Old 03-09-2013, 08:23 PM Thread Starter
So found a thread saying that 4in down pipe won't quite fit on a manual. No word on if you can make it work or not and that still does not explain why a manual only kit won't work on an automatic.
post #4 of 11 Old 03-09-2013, 08:24 PM Thread Starter
Lol ever feel like your talking to your self
post #5 of 11 Old 03-10-2013, 08:21 AM
Dirty_Stroke's Avatar
Unfortunately I am no help to you, but I can't believe one of the guys with a manual hasn't jumped in and answered your question. On one of the tune threads I saw somebody was running a manual and there sig said they had 4 inch exhaust. Look in the Tony Wildman review thread towards the beginning. It might have been in there.
05 F250 FX4 Lariat, SCT Livewire, 155cc injectors, Gryphon FICM tuner, ARP studs, MTW Stage 2 Turbo, Riff Raff boots, Warren Built trans, PMF traction bars ,4 inch straight pipe, Sinister EGR delete, S&B CAI, N-fab bars, level kit, 5% limo tint, 35 Toyos and 20s, Recon smoked everything, Harley headlights, 5k HID's, Camlocker toolbox, lots more
Dirty_Stroke is offline
post #6 of 11 Old 03-10-2013, 10:14 AM
Wyoming6.0's Avatar
Re: Manual vs auto exhaust
I just installed a 5" straight pipe ob my 06 cclb six speed. Mine said for automatic only too. I called thoroughbred diesel and they said it would fit. It was a pretty tight fit but I got it all installed
Wyoming6.0 is offline
post #7 of 11 Old 03-10-2013, 02:49 PM
william_ace's Avatar
Quoted: 2 Post(s)
That was probably me. I installed 4" exhaust on my truck and it went in just fine. I don't think you have anything to worry about.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #8 of 11 Old 04-22-2013, 04:43 PM
PowerStrokeAvenger343's Avatar
Can we have more?
Hey do you have more info on what you got? I have the same question as OP. If we could know what brand you went with and did it come with new down pipe? Thanks Wyoming!
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
-- Thomas Jefferson
BulletProofDiesel Oil Cooler/EGR Delete
Glowshift Oil, Coolant, EGT, Pyro, Fuel Pressure
CCV Mod
Harpooned
BPD 6 Phase FICM @ 53V
MBRP 4" Turbo Back Straight Pipe
PowerMax Turbo with MTW Single Plane Billet Wheel
SCT Tuned by Eric @ IDP
PowerStrokeAvenger343 is offline
post #9 of 11 Old 06-27-2013, 08:42 PM Thread Starter
I went with a dimond eye K5350A. Said auto only but fit great! 4in downpipe then 5in all the way back. Came with new 2 piece downpipe.
06 F350 ccsb zf6 Fx4 /Arp suds, egr delete, bpd hd oil cooler, swamps 58v FICM,5in turbo back str8, php ficm tunner w/egt probe, sct x3, bpd cac tube, diy regulated return, 6.4 banjos,ccv mod, zoodad, smoke switch, high idle, fan clutch switch, madmod, diy mesh grill, updated stc fitting ,stand pipes,dummy plugs
03 F250 stock but about to be torn down soon as i get time.
post #10 of 11 Old 06-28-2013, 04:48 AM
Quoted: 2 Post(s)
I think brand is going to play more of a part than size in fitment (to a point). I have a silverline 3.5" dp to 4" on my 07 6 spd and I am not very impressed with the fitment at all. I tried to clock, twist, nudge, turn, the down pipe and everything else to try to get it farther away from the starter housing. It doesn't quite have a finger width of clearance but it was the best I could do.
oilfieldtrash15 is offline
