Up pipe bolt sizes calling all techs - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-08-2013, 06:46 AM Thread Starter
Njstroker91's Avatar
Well I'm gonna have my trans out on Sunday for my new clutch so I figured its a good time to install the delete pipe for the up pipes since I just blocked it off initially. So my question is does anyone know the bolt size for the up pipes to manifolds and also the delete pipe bolt sizes. I have access to a variety of bolts metric and standard at work so any help is appreciated.
Sent from AutoGuide.com App
2006 f350 eclb 6 speed, powermax, billet compressor wheel, valair dual disk, 4in to 6in cat stack, afe magnum force stage 2, airdog 150, xdp sump, zoodad mod, sinister coolant filter, gauges egt oil temp and fuel pressure, cfm carbon fiber and metal cold side tub, blue spring, bpd ficm, moto metal 959 18x9 wrapped with cooper at3, custom shift knob from lilpooh, Polk audio all the way around, dashboss for monitoring
Njstroker91 is offline
post #2 of 10 Old 03-08-2013, 07:58 AM
JesseKK's Avatar
Quoted: 33 Post(s)
Garage
im not a tech but, i hav new bolts still in plastic bags from Ford. They r for teh uppipe and manifold connection. 2 3/8 long and its an M8. If im not making sense, let me know and i'll take pics of how im measuring.
JesseKFK
2007 F250 XLT CC 6.0 PowerStroke FX4 R.I.P. 3.6.16
Livewire TS LOoNeY
Studded
BPD 58v FICM
BPD Oil&Egr Cooler
Glow Shift Pyro,Fuel
High Idle Mod UF#4
Fog Light Mod
Harpoon Mod
Dome Override Mod
6000k Bi-neon Hids
Sinister Coolant Filter
8in Rize Ind 4 link
35" Mickeys on 20s
Blue Leds
Power Service Every Fill Up
ATV 2008 Yamaha Raptor 700 FI
KCCO
Originally Posted by Karls03 View Post
I hate Edge power products so much, I quit using Edge shaving gel
JesseKK is offline
post #3 of 10 Old 03-08-2013, 09:40 AM Thread Starter
Alright sweet deal so is that for the manifold or for the egr portion and do they look like a coarse or fine thread.
Edit: I didn't read your post all the way dumb me.
post #4 of 10 Old 03-08-2013, 09:42 AM
JJFLASH's Avatar
Quoted: 111 Post(s)
Just my .02 but for that kind of bolt I would get the correct hardware direct from Ford. Cost a few bucks but I wouldn't want to trust that kind of job to a "bolt I had laying around that threaded in ok".
-JJ-
Mine - 94.5 F250 ZF5: Basics w/a few extras, DIY bumper, steps and exhaust, AFEII, D60, PMF 2.25 RSK, V-codes
Hers - 04 GM 2500 CCSB 4x4: LB7, EFI Live by KW, 2" Lift, MBRP 4" dp back
RIP 15/08/23- 98 GM 1500 ECSB 4x4: 6.5, straight pipe, K+N filter, 495km w/original pump, trans & t-case
JJFLASH is offline
post #5 of 10 Old 03-08-2013, 09:47 AM Thread Starter
Well I can great anything from grade 8 hardware to 10.8 metric so if I can save a buck I'm gonna grab better hardware from work.
post #6 of 10 Old 03-09-2013, 12:22 AM
JesseKK's Avatar
Quoted: 33 Post(s)
Garage
Its fine thread. I can post pics if ud like. Those nuts were like $2 and teh bolts were $7.
JesseKFK
Livewire TS LOoNeY
Studded
BPD 58v FICM
BPD Oil&Egr Cooler
High Idle Mod UF#4
Fog Light Mod
Harpoon Mod
Dome Override Mod
6000k Bi-neon Hids
8in Rize Ind 4 link
35" Mickeys on 20s
Blue Leds
KCCO
JesseKK is offline
post #7 of 10 Old 03-09-2013, 01:16 AM Thread Starter
Well I grabbed some bolts from work if they don't work ill just head to the dealer and get some
post #8 of 10 Old 03-09-2013, 02:41 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
M8 x 1.25, various lengths
get the highest grade bolts you can
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #9 of 10 Old 03-09-2013, 06:51 PM
MWilbur516's Avatar
^^^THIS^^^ Always replace with the highest grade you can.
I said screw (no pun intended) the stock bolts and replaced mine with grade 8 hardware. I actually have mine off and on a shelf in the shop since I'm slappin' on my ceramic coated up and y-pipe. I'd go check em' for you, but I'm in my underwear, in bed, next to the wife and its cold outside. I'll get you lengths in the AM.
Matt | 2006 F250 XL FX4 6.0L 485RWHP and 968RWlbs-ft
Vision Diesel Performance503-487-6074
BULLET PROOF DIESEL 1-888-967-6653
TWISTED TRANSMISSION Contact me for a quote on a trans with the best warranty in the business.
MWilbur516 is offline
post #10 of 10 Old 03-14-2013, 08:18 AM Thread Starter
Thanks fellas didn't get it done but soon enough! Got my clutch in but was pressed for time so it's gonna have to wait till head stud time.
