which mtw should i get - Ford Powerstroke Diesel Forum
post #1 of 35 Old 03-07-2013, 10:32 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
So I wasnt originally going to even mess with anything like this but start looking at stuff and now I want a new turbo. I was just wondering what some differencesare between the stage 1 mtw and the hybrid are. If I went with the hybrid would I need any upgrades to my fueling system or can i drop the hybrid in and go? Its my understanding the stage 1 can work with stock tuning however I am getting idp for some custom tuning. If I get custom tunes writen for my stock turbo would they need rewriten for either of these setups? last question for now is would i def need my heads studded at this point with either of the turbos
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #2 of 35 Old 03-08-2013, 05:58 AM
Quoted: 5 Post(s)
Feedback Score: 3 reviews
Get a stage 1 with new billet wheel ..... Also talk to Adrian he is a good guy and will walk you through getting the correct setup
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #3 of 35 Old 03-08-2013, 01:24 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
What is the best way to contact him? Email?
04 f250 cc sb.
jmeaby is offline
post #4 of 35 Old 03-08-2013, 01:41 PM
Fox Hunt's Avatar
Quoted: 30 Post(s)
Hybrid, I love mine
2006 F-350 CCSB Lariat
MBRP 4" Exhaust, ARPs, Barder Stage 2 turbo, S&B CAI, TSD SPD, Warren Competition transmission, Edge CTS, Coolant Filter, High Idle Mod, CCV Mod, Zoodad, Newton Leveling kit, Fuel Mavericks 20x9 , Pioneer DVD head-unit, JL Stealthbox and JL Slash 500/1v2 amp
Future Mods:
Injectors and Driven Diesel RR
-Alex
Fox Hunt is offline
post #5 of 35 Old 03-08-2013, 01:49 PM
Gearhead2012's Avatar
Quoted: 3 Post(s)
It all depends on what you wanna do with the truck...I would tend to say go a little bigger now with the hybris rather than smaller in case you want to get into injectors or something later. I know there's a few guys running hybrids with stock injectors with good results.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #6 of 35 Old 03-08-2013, 02:01 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
So the hybrid isn't to big of a turbo for stock injectors? Or is it just about on the edge of as big as you can get. If I get bigger injectors they would only be 155's because I will also tow with this truck. With a new turbo will that increase my boost at all and would a new turbo mean I should get the truck studded?
04 f250 cc sb.
jmeaby is offline
post #7 of 35 Old 03-08-2013, 02:11 PM
Fordmanalan's Avatar
If it were me I would go with the stage one. are you planning on going up injectors? what are your goals? do you tow much with the truck?
2006 F350, 6.0, CCSB
ARP's, Pmax, CASS 190/100's, SCT SF3 Erics tunes, Swamps 58V FICM, DRP EGR Delete, NLF Intake Pipes, Flo Pro, DRP RR, Fuel Bowl Delete, P&P heads, DRP Fuel Sump, FASS 220 571 HP 35" Toyo MT's, 20" Fuel wheels, Bushwacker's, 08 Mirrors, O8 Rear, leveled, bilsteins, AMP steps, ROYALTY CORE GRILL
571 HP 1213 lbs ft torque
PROUD OWNER OF ONE THE FEW SHOPS IN THE NORTHWEST THAT SPECIALIZE IN THE POWERSTROKE ENGINE.
DIESEL WURX
LOCATED IN SRINGFIELD OREGON
541-868-6658
Fordmanalan is offline
post #8 of 35 Old 03-08-2013, 03:05 PM
Fox Hunt's Avatar
Quoted: 30 Post(s)
Re: which mtw should i get
No the hybrid isn't to big for stock injectors. Thats what I'm running. Have to try real hard to get any smoke outta this thing. Super clean now
Sent from AutoGuide.com App
Future Mods:
-Alex
Fox Hunt is offline
post #9 of 35 Old 03-08-2013, 03:31 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
id it change your mileage at all I would assume faster spool up and more air would equal better mileage
04 f250 cc sb.
jmeaby is offline
post #10 of 35 Old 03-08-2013, 11:45 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
If I got the.hybrid would.I have to.have a new tune written for.it?
04 f250 cc sb.
jmeaby is offline
