Boost issues... Thoughts? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-07-2013, 09:29 PM Thread Starter
bkingsoda's Avatar
Hi all! Kind of new around here, been looking around at some very interesting stuff though. Anyhow, I've been on power stroke nation a while and I'm not really finding a solution to my current issue. 2005 6.0 studded, deleted, 4" turbo back straight pipe, blue spring, metal cold side CAC, sinister elbow, SCT with tunes from IDP. Problem is that stock or running the tunes, the truck is not showing more than 22 lbs. Never has shown higher. It seems like that is very low for running hot tunes. Eric at innovative said its normal and boost is controlled by back pressure? Why are similar set ups making more boost? Am I making the boost and not seeing it? Factory gauge, watchdog, torque app, and scan gauge all max at 22lbs. Haven't put a mechanical on it yet, trying to figure out if it is gauge or part issue first. Any help or insight is appreciated. Thanks in advance, sorry for the long post.
bkingsoda is offline
post #2 of 6 Old 03-08-2013, 12:16 AM
turbotibbo's Avatar
i am not sure why you only see 22 of boost but i have heard of others saying the same . with custon tunes stock turbo i see 32 max boost then it levels out at 30 . is the turbo old or mabey rusting inside causing vanes to stick?
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #3 of 6 Old 03-08-2013, 02:12 AM
Chanzfx4's Avatar
Feedback Score: 3 reviews
Never ran Eric's tunes but with SRL I see spikes of 30+ and it levels to about 28-29. My wildman tune didn't get over 25, so I don't know. Have you ran any other tunes with different results? Might he a bad hose or vanes.
2003 White F350 Fx4 CC SWR
Go Fasts:
X2 tuned with SRL+
4 Inch Open Dp
Egr Delete
Blue Spring Mod
Riff Raff Boots
Sinister Coolant Filter
All Aluminum Radiator
ZooDad
Looks:
Blacked Tails
285/75/16 Destination M/Ts
Camo Interior
Leveled
Raised Black Nerf Bars
Black Bed Rails
Chanzfx4 is offline
post #4 of 6 Old 03-08-2013, 05:40 AM Thread Starter
bkingsoda's Avatar
Studs and delete were done a week ago. The turbo was out and looked great. Vgt duty cycle is right where it should be. Truck seems to make way more power with either hot tune loaded compared to stock, yet either way... 22lbs. Its just weird.
post #5 of 6 Old 03-08-2013, 06:35 AM
turbotibbo's Avatar
well mabey it has something to do with the ebp , i no when i did studs mine was dirty and rusted
blue spring mod
6.4 banjo bolts
air raid cold air
zoodad mod
high idle mod
58 volt ficm
egr delete
post #6 of 6 Old 03-08-2013, 06:54 AM Thread Starter
bkingsoda's Avatar
Hmm... Where can I find that at? I'm not sure if it was looked at when the truck was pulled apart. If it is dirty, can it be cleaned or does it just need to be replaced?
