Rear spring spacer block? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-07-2013, 04:36 PM Thread Starter
10secondC's Avatar
Do any of the vendors on the ORG. sell them? I need to do the left side spring to see if it gets rid of the lean and the Ford part is stupid for a block of steel. I figured I'd ask here before having one made.
2007 XL CC,DRW,4x4.
When I die I wanna go peacefully in my sleep like my Grandpa, not screaming in terror like the passengers in his car.
10secondC is offline
post #2 of 8 Old 03-07-2013, 04:52 PM
JJFLASH's Avatar
Quoted: 111 Post(s)
What exactly is the problem you are trying to correct...?
-JJ-
Mine - 94.5 F250 ZF5: Basics w/a few extras, DIY bumper, steps and exhaust, AFEII, D60, PMF 2.25 RSK, V-codes
Hers - 04 GM 2500 CCSB 4x4: LB7, EFI Live by KW, 2" Lift, MBRP 4" dp back
RIP 15/08/23- 98 GM 1500 ECSB 4x4: 6.5, straight pipe, K+N filter, 495km w/original pump, trans & t-case
JJFLASH is offline
post #3 of 8 Old 03-07-2013, 05:13 PM Thread Starter
10secondC's Avatar
Left side lean. There was a TSB about it and Ford has spacers to correct it but they are getting $270 for a spring block that can be made at a spring shop for less than $50.
2007 XL CC,DRW,4x4.
post #4 of 8 Old 03-07-2013, 05:14 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
If you have a lean you need to fix the weak spring!
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #5 of 8 Old 03-07-2013, 05:18 PM Thread Starter
10secondC's Avatar
Had the springs checked,replaced both fronts with 6500#. Still 1" to the drivers side.
2007 XL CC,DRW,4x4.
post #6 of 8 Old 03-07-2013, 05:20 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
how did they check the springs? did they remove them and have them load tested? if they didn't they where not checked. are you talking about 07/07/02 tsb?
A/C ASW A/W WINGS
post #7 of 8 Old 03-07-2013, 05:26 PM Thread Starter
10secondC's Avatar
Yes I had a spring shop do it. I am almost ready to just add a leaf but if a half inch shim fixes it I'll be happy. Not the TSB was in 05.....I know it ends in 05 but the trucks had the same rear suspension.
2007 XL CC,DRW,4x4.
post #8 of 8 Old 03-07-2013, 06:48 PM
colonel angus's Avatar
Quoted: 2 Post(s)
Check out icon racing they have blocks and awesome support.
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
