Loaded tune from SCT now speedo is way off - Ford Powerstroke Diesel Forum
post #1 of 16 Old 03-07-2013, 01:54 PM Thread Starter
Quoted: 97 Post(s)
Feedback Score: 3 reviews
So a little background. Turbo went out about a month ago and had it replaced under warranty. Warranty paid for most of a Powermax turbo. Get the Powermax on and like most said had a little bit of low end lag. So went looking for a tune to get rid of the lag and be able to tow if needed. Decided to go with Matt's 8k tow tune. Tune is great, shifts nice, no more lag and the EGTs have dropped.
So now onto the problem. The speedo is now off, it says I am going about 5 mph faster than I am really going. Before the tune it was dead on. I had calibrated it using the Superlift Truspeed.
So what can be causing this??? I did notice that the SCT asked me if I would like to calibrate my speedo and I said no. I did change under the options section my tire RPMs and my gear ratio. But I thought that only changed the shifting points. Please help.....
2006 F250 Carli 4.5" Pintop, Carli LT airbags, Top Gun Customz dual steering stabilizer, 4.30 gears Toyo MT 37's, Powermax, SCT X3 w/ Matt's 8k Tow tune, BPD 53 volt FICM, DC Power 185 alt, PMM coolant filter with Rotella ELC, Edge Insight CTS, MBRP 4", Line X'd bumpers, grille, and tonneau cover
villestrip is offline
post #2 of 16 Old 03-07-2013, 01:59 PM
jaysshortbus's Avatar
I always use my cts for that so it never changes but not sure if u can do that on just the insight !! It should have a place to enter stock tire size and then ask for new tire size then as long as thats plugged in your speedo is always on !
Jay
jaysshortbus is offline
post #3 of 16 Old 03-07-2013, 02:02 PM Thread Starter
Quoted: 97 Post(s)
I think you are talking about something else. I am talking about the trucks actual speedometer. I guess I could just readjust my Truspeed to match the correct speed.
post #4 of 16 Old 03-07-2013, 02:05 PM
So am I on my edge insight cts if I enter stock tire height and then after market tire height and its plugged in to my truck like it always is it automatically corrects my factory in the dash speedo for my bigger tires !!!
Jay
post #5 of 16 Old 03-07-2013, 02:10 PM Thread Starter
Quoted: 97 Post(s)
Thats the first I've ever heard of the CTS changing the vehicles speedo. I thought it was just a monitor. I don't see how that would have any effect of the trucks speedo.
post #6 of 16 Old 03-07-2013, 02:11 PM
Talking
Mine was like 3-4 off for almost 2 years before I realized I could use my insight for that !! If u need help shoot me a personal message and I will help u with it !!
Jay
post #7 of 16 Old 03-07-2013, 02:55 PM
Talking
Ok on mine u go to the options menu click on that then it should say tire size click on that then all u have to do is enter your stock tire height (I found mine in my fuel door) then enter the size your tires r now either metric or standard and its done !! Your speedo will be correct mine is about a 1/2 mph off but it's close enough for me !! U r correct it is for gauges but speedo is controlled by computer and insight is able to read gauges and codes from computer and even clear codes !! Good luck !!
Jay
post #8 of 16 Old 03-07-2013, 03:49 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 115 Post(s)
I'll need to try using the CTS. I've used the SCT to correct my speedo spot on with my GPS.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #9 of 16 Old 03-07-2013, 03:58 PM
Its nice because once its set u never have to mess with it after u change your tunes !!!!
Jay
post #10 of 16 Old 03-07-2013, 04:04 PM
N.S.D.Q.
Quoted: 115 Post(s)
Strange since my Speedo is dead on and the trip odometer is 1% off.
