sct (trans only tune) - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-06-2013, 08:38 PM Thread Starter
JustinOOO9's Avatar
Quoted: 521 Post(s)
Garage
so after getting and going through headache of updating sct tuner (thanks taylor at sct) for help.
i dont wanna run hp tune til i get studs because im weird...
what the heck does (trans only) do?
1. sct website doesn't even show it.
2. no luck at all on internet...
this is what i programmed my truck for about 3 hrs ago
tune- trans only
egr off-----does it do anything?
turned (shift firmer) on------what does it do, good or bad for trans? normal driving or only effects when in tow mode on truck etc...
thanks I have looked everywhere no one explains the trans only at all...
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #2 of 2 Old 03-07-2013, 07:05 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
Trans only tune is used mainly for heavy towing, that said running a canned hp tune without studs is safe. The custom tuners will ask if your studded or not and can build you a better tune than the canned tunes and it will be safe to use. Shift firmer is exactly that it will increase the firmness of the transmission shifts. EGR Off turns off the EGR valve and wont set a code. Under high boost you will still get some blow-by on the EGR valve. BTW I have a trans only tune and I had the programmer use the tow/haul button to set up a Jake brake. Hope this helps.
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is online now
