keep which FICM - Ford Powerstroke Diesel Forum
post #1 of 14 Old 03-06-2013, 07:36 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
keep which FICM
FICM #1 is a seven pin,atlas 80 tune nothing wrong with it. But the egt's with the atlas 80 tune are gonna bite me in the azz pullin over the divide this summer.
FICM#2 is a four pin that is shot. Needs to be rebuilt. 100% stock
So question 1, is there any benifit of a 4 pin or seven?
question #2 is the extra cash for the 53 or 58v up grade worth it?
question #3 Atlas 40 tune or what do you suggest?
If I keep the 4 pin and go with BPD power and Ed's atlas 40 tune thats what about $650...
Or do I just send the 7 pin that is working great but Im not all that jazzed about the Atlas 80 tune in,get the 40 for around $150......
Just wondering what your thoughts are guys, Thanks
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 14 Old 03-06-2013, 07:41 PM
ZMANN's Avatar
Quoted: 1894 Post(s)
are the logic sides both programmed to your truck ?
I would do the BPD power supply for the 4 pin logic side you have if that logic is programmed for your truck .. if it were mine
and I might skip the atlas for a while
Ed uses PHP you could just rent the programmer from them and not send it anywhere when and if you decide you want the 40
and then u could sell the 7 pin with the Atlas for some $$
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #3 of 14 Old 03-06-2013, 07:43 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
the 4 pin is the stocker out of my truck. the 7 pin is from Ed's ficm repair and throws a soft code. (I hope that answers your question...)
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 14 Old 03-06-2013, 07:47 PM
ZMANN's Avatar
so both are programmed for you kinda
I stick by my recommendation sell the 7 and buy the BPD either 4 or six phase
Why did u put a 7 pin inplace of a 4?
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #5 of 14 Old 03-06-2013, 07:50 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
My 4 pin was dieing quickly and I got a very good deal on the 7 pin. The 7 pin is 100% running great but the EGT's scare me.....
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 14 Old 03-06-2013, 07:52 PM
ZMANN's Avatar
I would do the 4 pin and loose the u0306 code
and personally I am not sold on the FICM programs specially if your running tunes
I think there will be improvements later on so I am waiting
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #7 of 14 Old 03-06-2013, 07:54 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Right on thanks!
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #8 of 14 Old 03-07-2013, 04:37 PM
Chatham036's Avatar
Quoted: 149 Post(s)
keep which FICM
Just to satisfy my curiosity.. Why are you against the FICM programs? Any quantitative reasoning?
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #9 of 14 Old 03-07-2013, 08:20 PM
1fastTRX's Avatar
Re: keep which FICM
I don't know about your situation because it sounds like your 7 pin w/atlas 80 was purchased somewhere else, but a different ficm tune is $50 from PHP if you already have it tuned. I've been thinking about getting my economy tune (original before the bigger stuff came out) swapped for the atlas 40. I had gotten it tuned through PHP originally. Only downside is I have to send the ficm back again. No remote tuner, but I can see why he does it like that.
2006 F-250 CCLB Lariat FX4
4" Rancho Lift with Wireless Ride adjustment (came with truck)
35" Toyo A/T Tires on 20" Eagle Alloys
4.10 gears
Barder Stage 2 turbo
Ported intake manifold (Thanks odawg714)
ARP Head Studs
Bulletproof EGR Cooler
Tunes by Gearhead (SRLXX daily)
Dieselsite Coolant Filter Kit
ISSPRO gauges: Trans, EGT, Fuel Pressure
Airdog II 165
6.4l Banjo Bolts
PHP Original FICM tune
1fastTRX is offline
post #10 of 14 Old 03-10-2013, 07:29 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
I got mine from another guy on the site and he had it tuned at FICMrepair.com. I may just send it in a get the retune like your sayin...
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
