Runnig Open Thermostat? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 03-06-2013, 03:01 PM Thread Starter
FORD4LIFE
powerstrokeculver's Avatar
Quoted: 2 Post(s)
Question Runnig Open Thermostat?
So I tried doing a search for my answer but couldn't really find anything. I know that heat is one of the biggest killer of these engines. I live in Vegas where it can get up to 120 in the summer. My question is would it be good to run without a thermostat durrning this time? Is there any downside to this when it's that hot out? Wouldn't it keep everything cooler and running smoother? Let me know what you guys think.......
Work Horse
2006 F250 FX4
6'' Lift Donahoe Racing
Toyo ATII's 35x12.5R18 on Moto Metel Black
BPD Engine Oil Cooler
BPD FICM 53V
K&N CAI
4" Straight Pipe
XDP Coolant Filter Kit
Blue Spring mod
SCT Tuned by DP-Tuning
ARP Head Studs
Nothing But AMSOIL!
To-Do list:
FICM Tuning By PHP
155cc or 175cc Injectors
Stage 1 or 2 Turbo
BPD Water Pump
powerstrokeculver is offline
post #2 of 20 Old 03-06-2013, 03:16 PM
Tj Krawler's Avatar
It would keep the motor cooler, but you don't necessarily want the motor running cool. It would be less efficient at say 150*, than 192*. A lot of the 6.0 guys will replace a thermostat when they're running just a few degrees low.
If you're having overheating problems, you might have other problems. If it's not overheating, don't fix what isn't broke.
Alan
2000 F-350 CC LB DRW 4x4 XLT Auto
- Intake
- Exhust
- ScanGauge
Tj Krawler is offline
post #3 of 20 Old 03-06-2013, 03:25 PM Thread Starter
FORD4LIFE
Quoted: 2 Post(s)
I've only had the truck for a few months now. It hasen't been through a summer here. My ECT right not stays 180-190, depending on if I get on it or just putting along, and my EOT stay at about 190. My temps look good when I'm driving but I wanted to keep it that way. Thats why I asked.....
Work Horse
2006 F250 FX4
BPD FICM 53V
K&N CAI
4" Straight Pipe
Blue Spring mod
ARP Head Studs
Nothing But AMSOIL!
To-Do list:
FICM Tuning By PHP
Stage 1 or 2 Turbo
BPD Water Pump
post #4 of 20 Old 03-06-2013, 03:35 PM
rdunagan's Avatar
it will stay that way. summer it will heat up alittle but overall it shouldnt overheat. if it does you have problems elsewhere
2009 Ford F-350 FX4 4x4, H&S 300HD, MBRP 5" DP back exhaust, S&B intake, sinister egr delete, 4" BDS lift with fox shocks, 20x12 fuel nutz, 37" toyos, Custom painted headlights by me
SOLD: 2006 Ford F-350 4x4 King Ranch,ARP Head Studs and all the works
rdunagan is offline
post #5 of 20 Old 03-06-2013, 05:49 PM
running without a thermostat will not make the engine run cooler, it will show cooler on the gauge but everything is hotter. There has to be a restriction in the sytem for it to properly absorb and dissapate the heat through the cooling system. Race cars don't run a thermostat, instead they use a restrictor in the housing to slow down the coolant flow to get the coolant to the temperature they want without running the risk of a stuck thermostat.
jpott62 is offline
post #6 of 20 Old 03-06-2013, 05:54 PM
ZMANN's Avatar
Quoted: 1343 Post(s)
Agreed
if coolant doesn't stay in the radiator long enough it won't cool down
removing a t-stat in any application I have ever dealt with is a bad plan
We Miss you Ronnie
ZMANN is offline
post #7 of 20 Old 03-07-2013, 01:39 AM
Justin@DP-Tuner's Avatar
Quoted: 45 Post(s)
Originally Posted by ZMANN View Post
Agreed
Leave the thermostat in. You should not have a problem with overheating.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #8 of 20 Old 03-07-2013, 08:36 AM
Chatham036's Avatar
Quoted: 130 Post(s)
DieselSite does offer multiple grades of thermostats... you can select which temp you want it to open by which t stat you purchase..
www.dieselsite.com
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #9 of 20 Old 03-07-2013, 08:46 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
www.dieselsite.com
Not for the 6.0.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #10 of 20 Old 03-07-2013, 03:12 PM
PGreenSVT's Avatar
The diesel, being a compression ignition engine likes heat. It should have an egt between 190 and 200. If it is consistently running below 186 it would suggest the thermostat is stuck open and it should be replaced.
Typical eot should be 192-194 and eot 196-198. The 6.0 is not a gasser and gasser logic does not apply here.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
