how do I figure out what chip I have?? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-06-2013, 11:54 AM Thread Starter
so I bought an 03 f250 and it has a hard wire chip I believe in my fuse box under the dash there is a single wire with a fuse plugged into an auxiliary slot.
bsmolen is offline
post #2 of 13 Old 03-06-2013, 12:17 PM
Gearhead2012's Avatar
Quoted: 3 Post(s)
Is it a 6.0 or a 7.3 liter? If its a 7.3 post this question there...if its a 6.0 they don't have "Chips" they use programmers or tuners most are removable. What you're describing could be banks or older stuff. Or it could be a wire for a display screen that might no longer be there.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #3 of 13 Old 03-06-2013, 12:26 PM
doubledrop's Avatar
Sounds more like an add-a-circuit to the existing fuse box. What else is it connected to? Prob was just a way to provide power to something like gauges, etc.
http://www.amazon.com/gp/aw/d/B0002BGELQ/ref=mw_dp_mpd?pd=1
Sent from AutoGuide.com App
__________________________________________________ ______________________________
doubledrop is offline
post #4 of 13 Old 03-07-2013, 10:14 AM Thread Starter
well when I plug it in I can hear my fuel pump get louder and my MPG's will go up
bsmolen is offline
post #5 of 13 Old 03-07-2013, 10:46 AM
doubledrop's Avatar
is this a 6.0 or 7.3 2003? they had both. The programmers/chips work completely different. It doesnt sound like any 6.0 programmer I have heard of though. you shouldnt hear a the fuel pump get louder and MPG usually only go up if you can stay off the gas pedal with the xtra power.. can u get pics of what you are talking about?
post #6 of 13 Old 03-07-2013, 06:26 PM Thread Starter
It is a 6.0 and yeah I can get pics posted tomorrow. It's a 2 amp fuse. I don't know but if its plugged in and I go to start it cold The fuel pump is a lot louder than when it's not plugged in
bsmolen is offline
post #7 of 13 Old 03-08-2013, 01:32 PM Thread Starter
here is a pic and it was a 3 amp fuse
bsmolen is offline
post #8 of 13 Old 03-08-2013, 02:31 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
That is a add-a circuit. I don't know what it is connected to but I doubt that it is a programmer or "chip".
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #9 of 13 Old 03-08-2013, 03:16 PM
doubledrop's Avatar
Yep. Need to trace the wire and see where it goes
post #10 of 13 Old 03-08-2013, 04:39 PM Thread Starter
Think I figured it out... I found a after market fuel water separator and a fuel filter under drivers side
bsmolen is offline
