Looney tune smoke - Ford Powerstroke Diesel Forum
post #1 of 14 Old 03-04-2013, 03:16 PM Thread Starter
Frankf250's Avatar
Looney tune smoke
What's up guys. Just wondering if anyone can tell me how much the looney smokes on their truck. Vivian said it shouldn't be too bad but I'm smoking a LOT so I think I have a problem. Anyone have any input on the amount.
Sent from AutoGuide.com App
Frankf250 is offline
post #2 of 14 Old 03-04-2013, 04:13 PM
portcity_gt's Avatar
Quoted: 1361 Post(s)
Just a pretty solid puff durring spool up, then a light haze at wot.
If its smoking bad you probably have a sticking unison ring it the turbo.
What year truck and how much boost is it making?
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #3 of 14 Old 03-04-2013, 04:21 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Looney tune smoke
Or cracked flex joints at the up-pipe/y-pipe, or CAC system leak.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 14 Old 03-04-2013, 04:29 PM
Yea that's why I asked about boost.
And the year, being the 05's are the retards of the 6.0's.
post #5 of 14 Old 03-04-2013, 04:55 PM Thread Starter
Frankf250's Avatar
Looney tune smoke
It's an 07 with 68,xxx on it. Turbo will go up to 26-27 psi. On the freeway if I'm cruising at 60-70 and push down maybe half throttle she blows a big cloud. I keep getting flipped off. From a stop I have to ease into it or it blows hard and if I just tap the pedal like half way and let go quick it puffs out a little dark cloud.. Only mod is the 4" turbo back straight pipe
post #6 of 14 Old 03-04-2013, 04:56 PM Thread Starter
Frankf250's Avatar
Looney tune smoke
Anyone wanna send me a video of the passenger mirror on take off ? Haha
post #7 of 14 Old 03-04-2013, 05:02 PM
JesseKK's Avatar
Quoted: 51 Post(s)
Garage
mine will smoke if i snap teh throttle, but any other time its just a haze
JesseKFK
2007 F250 XLT CC 6.0 PowerStroke FX4 R.I.P. 3.6.16
Livewire TS LOoNeY
Studded
BPD 58v FICM
BPD Oil&Egr Cooler
Glow Shift Pyro,Fuel
High Idle Mod UF#4
Fog Light Mod
Harpoon Mod
Dome Override Mod
6000k Bi-neon Hids
Sinister Coolant Filter
8in Rize Ind 4 link
35" Mickeys on 20s
Blue Leds
Power Service Every Fill Up
ATV 2008 Yamaha Raptor 700 FI
KCCO
Originally Posted by Karls03 View Post
I hate Edge power products so much, I quit using Edge shaving gel
JesseKK is offline
post #8 of 14 Old 03-04-2013, 05:05 PM
Why don't you email Vivian?????
Mine smoked black if you stomp on it with no boost, but that makes sense. If you already have built boost and you mash it, you should see a solid haze as you warp to light speed.
06 F250 White Supercab 4x4
"Some mods"
californiadreamin is offline
post #9 of 14 Old 03-04-2013, 05:13 PM
Is it bogging down? That will cause smoke. The converter could be locked up too soon, Vivian should be able to fix you up one way or another.
post #10 of 14 Old 03-05-2013, 07:04 AM
sbarbee54's Avatar
I had this issue when i first got her tune, and the problem was this "If its smoking bad you probably have a sticking unison ring it the turbo." Replaced it ran fine, then threw a 03 on it ran fine, just took the 03 back off and put the 05 back on with the new uni ring and is fine.
Now on snap throttle I get a puff, when crusing and go to WOT haze, unless it is very low boost and it down shifts and it tends to take a little longer to spool back up then I get a slight puff then a haze.
2005 F-250 CC SB FX4 Lariat 6.0
SCT Live Wire Tunes By Quick Tricks
MRBP 5" Straight Pipe
Banks Intake
GlowShift 4 Pillar/4 Mirror Pod
Kenwood DNX8120/Diamond Audio System
10" Sky Jacker Lift W/Procomp Rezies
Amp Steps/TopGun Customz Dual Fox Stear
Yukon 4:56's
Zoodad Mod/6.4 Banjo Bolts/Blue Spring Mod
PMF Trackbar/Draglink
20" Helo Maxx 8's W/ Toto MT 38X15.50R20's
sbarbee54 is offline
