37's Vs. 35's Opinions - Ford Powerstroke Diesel Forum
post #1 of 28 Old 03-03-2013, 05:42 PM Thread Starter
colonel angus's Avatar
Quoted: 2 Post(s)
I have an opportunity to grab 4 nearly new Mickey Baja AT's for $600.00 and was wondering what other have preferred 35's or 37's and was there that big a difference in mileage, performance and ride quality.
I' have the Icon 4.5" looks llike i'll need the TEI and possibly a taller block or 1" spacer just to keep the ride level.
There's tons of room in the rear but the fronts will likely hit the lower fender well support.
If the TEI doesn't work i'll be looking for a set of 18" OEM's as they don't poke out as much and from what I've read with 37" tires and stock wheels even a 4" lift is sufficient.
Help Please.
denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #2 of 28 Old 03-03-2013, 09:02 PM
I'm not sure what a TEI is, but I do know that with about 4"~5" up front (it's a long story, don't ask), I can contact the fender pulling into a parking lot. That being said, I would be going to a 6" lift if I went 37s. I certainly wouldn't go wheelin like I do on 37s without a 6" lift. Wheeling with 35s has proven the need for the hammer mod on the front fenders. The other thing that I would do if I had 37s would be to go with 4.30 gears.
As far as mpg, going from 33s to 35s, I dropped 2 mpg like it was cool. I can only imagine what I would lose going to 37s. A friend had 38s (yes I know you said 37, but it's close enough for gov't work) with 3.73s and said his mileage was really bad.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 28 Old 03-03-2013, 10:26 PM
asian195's Avatar
Quoted: 2 Post(s)
Re: 37's Vs. 35's Opinions
Talking to others with 37s and stock gearing, they pretty much said it's a dog and bad mileage. Depending on your wheel offset, they might rub, they might not. I run 35s with just a leveling kit, with minor rubbing on fender well..
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
To Do/Wish list:
FICM tune
ARP Head Studs
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #4 of 28 Old 03-04-2013, 09:31 AM
Gearhead2012's Avatar
Quoted: 2 Post(s)
I've run both, just recently put 37's on mine. Tsl boggers...they're on 17" fuel hostage rims. Now...the boggers kinda add a grey area to the ride comfort category...its like riding on tractor tires. Aside from that, it rides OK when the tires warm up and stop bumping along with the flat spots from sitting all night...gotta love bias ply. I don't get stuck anywhere anymore, lol.
I run a 4.5" icon kit, fox racing shocks with external resevior, and some cheapy eBay leveling spacers under the front spring perch...its 2.5" tall, and a 3 inch block in back in addiction to the 5 Inch block the icon came with.
Ride is better than stock...I need a steering stabilizer and an alignment badly, but again the boggers play into making the road manors worse. If they were a good radial tire like what you're looking at, I wouldn't have any complaints. My mileage has been crap with trans issues I'm having... but I hasn't seemed to get much worse with tires. Definitely not a pig with a tune and ficm tuner. I don't see any huge need to regear right now. If I was going much bigger than 38's I would regear but I wouldn't say its necessary...my truck has 3.73's stock...I think most of the diesels do...maybe some have 4.10's?
All in all I'm pretty happy with it.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #5 of 28 Old 03-04-2013, 10:13 AM
ZIKA's Avatar
I run a 37/13.50 with a 4-Link BDS 6" lift. It only rubs the inner liner on tight parking lot manuvers. It was a little sluggish with the stock 3.73's untill I switched to a 4.56 which is very steap. 4.30's might be a little more road friendly.
06 F250 Reg Cab. ARP's, RCD Billet Powermax, Warren 190/100's, Areo A1000 Pump, Driven Diesel Reg Return, All AN Lines from the sump, Intake and Exhaust, 4" BDS Lift, Long Arm 4-Link, Dana 80 swap, 1480 u-joints, 4"/.108 driveline, Detroit Lockers (both axles), Warren Trans w/ Billet Shafts, Drive Flanges, 35"s, Traction Bars, Front Suspension Stops(For Tug-A-Truck), Rear Suspension Stops, Custom Hitch, Roll Pan, Lots of Drive Shafts, Axles, and Pinions.
ZIKA is offline
post #6 of 28 Old 03-04-2013, 10:20 AM
Dirty_Stroke's Avatar
Gearhead, got any pics of your truck on Boggers? I bet it looks freaking mean as hell.
05 F250 FX4 Lariat, SCT Livewire, 155cc injectors, Gryphon FICM tuner, ARP studs, MTW Stage 2 Turbo, Riff Raff boots, Warren Built trans, PMF traction bars ,4 inch straight pipe, Sinister EGR delete, S&B CAI, N-fab bars, level kit, 5% limo tint, 35 Toyos and 20s, Recon smoked everything, Harley headlights, 5k HID's, Camlocker toolbox, lots more
Dirty_Stroke is offline
post #7 of 28 Old 03-04-2013, 05:50 PM
jetjock15's Avatar
Quoted: 110 Post(s)
I have 37s on 10" lift and have smashed my front fenders and my bed. Depends on how much your suspension actually travels and how hard you push them. If I ran 37s on 4 or 6" I would just remove the fenders and the bed.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #8 of 28 Old 03-04-2013, 06:11 PM
Quoted: 2 Post(s)
I'll get some up soon and maybe update my profile pics and all finally.
Yeah I gotta watch mine, if I push it really hard crossing ruts in the sand I can watch mine come pretty close to the fenders on compression. I need to drop my bump stops down, or even invest in a nice set of gas bump stops.
Under construction
Machining the 6.0:
post #9 of 28 Old 03-04-2013, 06:17 PM
wired1's Avatar
depending on wheel off set you may rub even with the 1" tei spacer. And 37" vs 35" I saw a 1.5 mpg drop when I made the switch but the look it worth it to me for the trade off in mpg!
2013 F150 FX4 EcoBoost fully loaded with the app pkg on Icon 2.5" coilovers
06 F350 Lariat-PMF 8" on 37'sSold
09 F350 ccsb Pmf 7" on 37's Sold
01 F250 ccsb 6" on 35's with to much to list Sold
98 Cobra Vert 583 RWHP Sold
wired1 is offline
post #10 of 28 Old 03-04-2013, 06:21 PM
Quoted: 2 Post(s)
Also I forgot to mention my 35x12.50's would rub the radius arms occasionally. They were on the stocj Harley 20" rims so no positive offset...or is it negative...anyway they were stock. Maybe I already said this...I seem to remember typing it recently. Oh well.
Under construction
Machining the 6.0:
