Been away a while need som updating one the "new" stuff - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-02-2013, 09:15 PM Thread Starter
sbarbee54's Avatar
So I have been away because when I get on this forum I spend money! I love my 6.0. Well I am not married yet but I just paid off my 22K wedding and 4K honeymoon so back to the forum.
So I am in need od some info on what is new and what should I look to do.
Like best wheels for turbos for a 03 turbo and a powermax.
Who is doing the best tunes now a days or who are the good ones now.
Who is programing Ficms now and who should I look at
Is BPD still the best solution for remote oil cooler.
Who is still doing egr deletes, complete deletes or welded off live in Cali and still need to pass visual.
Also any new innovations in the past year or so I should look to do.
2005 F-250 CC SB FX4 Lariat 6.0
SCT Live Wire Tunes By Quick Tricks
MRBP 5" Straight Pipe
Banks Intake
GlowShift 4 Pillar/4 Mirror Pod
Kenwood DNX8120/Diamond Audio System
10" Sky Jacker Lift W/Procomp Rezies
Amp Steps/TopGun Customz Dual Fox Stear
Yukon 4:56's
Zoodad Mod/6.4 Banjo Bolts/Blue Spring Mod
PMF Trackbar/Draglink
20" Helo Maxx 8's W/ Toto MT 38X15.50R20's
sbarbee54 is offline
post #2 of 8 Old 03-03-2013, 06:34 AM
jetjock15's Avatar
Quoted: 113 Post(s)
Turbo - MTW
Tunes - DP Tuner
FCIM - Ford
Oil cooler - BPD
Cali shops - everywhere
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #3 of 8 Old 03-03-2013, 06:49 AM
5fifty's Avatar
While I am not the most seasoned 6.0 guy out there, one major change to note:
BPD did add another version of their remote cooler kit. It utilizes the OEM oil filter assembly instead of the wheel well spin on filter. Not sure if you have seen that yet.
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #4 of 8 Old 03-03-2013, 08:07 AM
portcity_gt's Avatar
Quoted: 1338 Post(s)
Mad turbo werks for the wheels
You still have all the same big tuners, but tony wildman is making the biggest splash right now.
I'm running a completely redisined ficm from bulletproof deisel, and I'm using a gryphon programmer from power hungry performance so I can load my own ficm tunes.
Yes bpd is still the best solution for the oil cooler by far, they now have a few options for the coolers, I'm running the new one that uses the oem filter.
I'm using a run of the mill egr delete from pmm, ipr makes a real nice delete (genII) but it won't pass visual for you. Bpd makes a egr cooler that won't fail like oem.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #5 of 8 Old 03-03-2013, 08:50 AM Thread Starter
sbarbee54's Avatar
Big thing I want to do right now is put the 03 turbo I have sitting around instead of stoke but looking to see if there are wheel upgrades for it like if bantom or wicked make them or any one else.
Also have a bad fcim sitting around I want to send in to get tuned so who is doing that now a days
And what new parts were released in the last year I should look at, any new up and common 6.0 parts mfg or still mainly bpd
Banks Intake
Yukon 4:56's
post #6 of 8 Old 03-03-2013, 09:13 AM
Well, like I said mad turbo werks for any turbo needs.
If the ficm is bad tuning it won't do any good. I you want to get it fixed, Ed at ficm repair.com. But I highly recomend one of the new ficm's from bpd.
post #7 of 8 Old 03-03-2013, 09:17 AM Thread Starter
sbarbee54's Avatar
Well mine is good but does swamp still to the repair work and tune it or have the finally released there tuner you can buy and tune it?
Also maybe I should just do the turbo all together is a slight best stoke upgrade still the power max? I have heard it tends be be a slight slow spooling
Banks Intake
Yukon 4:56's
post #8 of 8 Old 03-03-2013, 10:02 AM
I win....
cRaZy8's Avatar
Quoted: 47 Post(s)
Garage
Listen to Nick-portcity, the BPD FICM is "fix it once and forget it" fix.
Completely redesigned unit, built in redundancy backup circuits.
I run an IDP FICM tuner and like it, many others avail.
BPD just released a new oil cooler kit.
Welcome to Mad Turbo Werks!!This guy is the newest badass on the block when it comes to turbos, and wheels, super nice guy, infinite turbo knowledge for the 6.0L.
S362 68/.91
Irate SS T4
Holders 175/30
BPD FICM
BPD Cooler
BPD WP
ARP
Yukon Locker
4.30's
ODP St3 Manifold
NL CAI
Rudy's Intake elbow
PSP Coolant Tank
Mishimoto Rad. & IC pipes
EGR Del.
Edge CTS2
SCT X3
FICM Tune
Jugger Pump w/DIY RR
Fuel PSI Gauge
35x18's
Bilstein 2.5"
Trac. Bars
DC Power
Powerstops
USCG 50GT MMC
Yamaha Outboard Master Tech
cRaZy8 is offline
