rev x all the way! - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-01-2013, 05:36 AM Thread Starter
livinlots26's Avatar
rev x all the way!
So I finally got my last oil change/test done. My testing was on the three main oil additives that get the most hype. 1, hotshots secret 2, archoil and 3, rev x. So ill start with hotshots, now to my knowledge I don't have didn't have any stuck or failed injectors. I didn't really find hotshots made any difference what so ever in performance fuel economy or quieting the injectors, my test sent to the refinery didn't show much improvement in extended lubricity or extded life over my initial "no additive" test. So in my eyes although its easy ro buy at any tractor supply store I think its useless. Next I tried the archoil. I did notice a lot better cold starts (its been winter during this test) even over the hot shots which was done in the summer. The injectors seemed a bit smoother and test came back with much greater extended performance all over the board. That being said I did notice towards the last 1500 miles the injectors were getting a little louder. Fuel mileage was same as both hotshots and no additive. Finally the rev x. Although archoil uses a "nano borite" and rev x larger particle borite, I found after my first 2 runs an incridible difference in performance with crisp throttle response and much quiter injectors. My fuel mileage has increased by about .5 a mile and has a nice smooth idle. All my tests should be fairly consistant I fuel at the same station every time I drive the same route everyday and nothing has been changed to the truck since I started. I have not sent in the rev x oil sample for this test is only 500 miles in. Its odd how the oil you put the least amount of in your engine seems to work best! Ill keep you posted when I send in the sample, but so far rev x is the winner for me
4 inch down pipe 5 inch stacks no cat, Powermax turbo, CFM large mouth intake elbow with larger pipe, S&B cold air intake, Edge juice with attitude CS with custom PHP tune. Atlas 80 ficm tune. Airdog2, TRP sump, 6.4 banjo bolts, Blue spring, Zoodad mod, Traction bars, counter sunk tool box molded around my stacks made by me, Coolant filter, ARP head studs, southbend duel friction clutch, complete EGR delete, DP mod, high idle mod, CCV relocation, 35 inch fierce attitude tires on 17" helo wheels
livinlots26 is offline
post #2 of 13 Old 03-01-2013, 01:22 PM
jetjock15's Avatar
Quoted: 113 Post(s)
I personally think all three of those products are a blatant joke, but I comend you for a great test and post. Interesting to hear about real observations. Did a good job of controlling the variables you could keep consistent. What do those products rank in price? Numerous blind studies prove the more one spends the more they are sure they get a better product, even when a placebo is used
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #3 of 13 Old 03-01-2013, 02:05 PM Thread Starter
I guess some what true... rev x is the most compaired to how much you get. Rev x is roughly 60 bucks for 2 four oz bottles. Archoil is about 38 bucks for 16 oz and hotshots is 50 bucks at 64 oz. So maybe its all a hoax but hey the trucks still running lol! By the way sick truck jetjock!
post #4 of 13 Old 03-01-2013, 02:25 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Rob, I have used Rev_X and saw a noticeable difference in idle smoothness, turbo spool up, and cold starts. This was in my truck with no injector issues and Amsoil 5w30. Here in the next month I will be doing fresh T6 and Archoil 9100. I am just curious.
RIP Mitch
the Org crew
PGreenSVT is offline
post #5 of 13 Old 03-01-2013, 02:44 PM
jetjock15's Avatar
Quoted: 113 Post(s)
We have disagreed on this before! Lol. If it helps it helps!
post #6 of 13 Old 03-01-2013, 03:17 PM
RedneckYankee's Avatar
I tried HSS and was not real impressed with it. Didn't seam to do anything for quieting down injectors. The place I bought it from asked me to let them know if it did anything that it advertised when I told them no it didn't they handed me my cash back. At least I wasn't out anything but fuel to get there. Haven't tried RevX. I have used 2cycle and Diesel Kleen and that quieted the injectors and smoothed out idle.
David
"Hold my beer and watch this"
2005 Excurstion Limited RWD
Sinister EGR Deleate
SCT Tuner MPT Custom Tune Econ/Perf
Dash Boss Monitor
Blue Spring Upgrade
Nitto Terra Grappler 285/75/16
Bilstien 4600 shocks
No Kitty
4" Straight piped
Studded
Updated Stand pipes and Dummy Plugs
1996 F250 XCLB 4x4
4" Ruff Country Lift
Ruff Country N2O Shocks
RedneckYankee is offline
post #7 of 13 Old 03-02-2013, 03:29 AM
My truck would run rough at start up. Just for a few seconds and it got worse the colder it got. I read on this forum about Rev-X and gave it a try.... All I can say is it will be in every oil change from now on. It was like being on an infomercial. You could hear and feel a difference in the truck right away. 60 bucks is worth it as far as I'm concerned. Just my 2 cents and worth about the same....
tartfun is offline
post #8 of 13 Old 03-02-2013, 03:42 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
I did a similar test about a year ago.
The archoil was a waste of money IMHO
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #9 of 13 Old 03-02-2013, 04:15 AM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
AGREED 110% TOTAL B.S. you cant fix something that is worn physically you can only bandaid for a little bit!!
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #10 of 13 Old 03-02-2013, 05:11 AM Thread Starter
I don't think its trying to fix a worn out part. These new oil restrictions are taking a lot of needed lubrication properties so I'm thinking the additives are just helping. And as far as the stuck injectors go I cant say for sure cause I've never had one to test this on. I guess if it has some penetrating properties it could eventually relieve one But as far as helping a motor run smoother and qeiter and get a little better fuel mileage I think is spot on for rev x. I will also add my cold starts are hand over fist better not a single stutter after it fires, and by cold I mean 10 degrees.
