injectors upgrade without turbo upgrade. - Ford Powerstroke Diesel Forum
post #1 of 21 Old 02-28-2013, 06:29 AM Thread Starter
dpmac83's Avatar
Hey guy It looks like i have at least 1 injector going out on my 05 F250, My question is what size over stock can I put in my truck without upgrading my turbo.
I am not looking for crazy horsepower just a fun daily driver. I have studs, egr delete, 4" exhaust, blue spring, and some other stuff but. no programmer looking to upgrade as things break.
dpmac83 is offline
post #2 of 21 Old 02-28-2013, 07:01 AM
rdunagan's Avatar
175/stock is as big as i would go without pulling fuel
2009 Ford F-350 FX4 4x4, H&S 300HD, MBRP 5" DP back exhaust, S&B intake, sinister egr delete, 4" BDS lift with fox shocks, 20x12 fuel nutz, 37" toyos, Custom painted headlights by me
SOLD: 2006 Ford F-350 4x4 King Ranch,ARP Head Studs and all the works
rdunagan is offline
post #3 of 21 Old 02-28-2013, 07:10 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Even with a 175/stock your going to need fuel pulled.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #4 of 21 Old 02-28-2013, 07:14 AM
strokin6L's Avatar
Quoted: 4 Post(s)
i ran my 190/75's with full fuel on stock turbo with zero issues for over a year and many others have done the same. You'll be fine with a 190cc injector and stock turbo.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #5 of 21 Old 02-28-2013, 07:19 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
You have a stock turbo and no tuner. Replace the bad injector with a stock reman and get an SCT X3 or SF3 and some custom tunes. Biggest bang for your buck right there.
Put your mods in your signature so we know what you have. Hard to advise you without knowing that. For instance, do you have a monitor or gauges to know what your engine is doing?
RIP Mitch
the Org crew
PGreenSVT is offline
post #6 of 21 Old 02-28-2013, 09:07 AM Thread Starter
dpmac83's Avatar
Well i plan on getting a tuner, but for the moment I am looking at the bucking issue. I would like to run larger than stock injectors and keep my current turbo set up until it craps out at which time I will upgrade the turbo. kind of an uprade it when it breaks plan.
Correct me if i am wrong but the 155 or 175 number is the capacity of the injector and the 75 number is the nozzle size in percentage over stock size right??
if that is correct going with a larger capacity with a stock nozzle size should give me more fuel at the same injection rate as stock. While going with a 175/75 gives me more fuel and faster??
05 F250 CCSB Lariat 3" level with 35x12.5R20 Toyo Open Country MT
EGR delete
Studs wOEM gaskets
blue spring
Zoodad
CFM largemouth
MRBP 4 in turbo back
CTS Monitor W/egt
Coolant filter w/ CAT ELC
FICM replaced
STC replaced
HPOP replaced
IPR replaced
$$$Looking at this list makes me want to sell my truck!$$$
dpmac83 is offline
post #7 of 21 Old 02-28-2013, 10:03 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
That could be a long time, your turbo may never go south! Since the turbo is the limiting factor to smokeless performance, you would notice a big difference with stock injectors and a hot tune! If you increase your injectors, do the nozzles as well. If you do that, you will need a bigger blower. It all goes together.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #8 of 21 Old 02-28-2013, 10:08 AM
Quoted: 47 Post(s)
Yes
Not necessarily. It could give you more fuel available at lower RPM and a longer PW. However, at higher RPM it will be about the same as a stocker. The issue is if you get new nozzles, their stock may be larger that the originals, or your old ones will be used enough to degrade performance. The real answer lies in ICP, PW and fuel available (bore and nozzle). Flow-testing is the only way to know for sure.
Frank
Working for Toys
post #9 of 21 Old 02-28-2013, 10:11 AM
PGreenSVT's Avatar
So you are leaving important details out. You think an injector is going bad. Why? Now you have a bucking issue. Are you talking about the turbo surging? If so have you cleaned the turbo. The vgt vanes are prolly sticking on you.
Yes on the injector numbers, you have it right.
155/30's and an MTW Stage1 with a billet wheel will be a whole lot of fun.
RIP Mitch
the Org crew
post #10 of 21 Old 02-28-2013, 11:50 AM Thread Starter
dpmac83's Avatar
Pgreen... I actually just cleaned the turbo last weekend, It actually didnt look bad at all. I cleaned it anyway. The turbo doesnt surge at all. Just a bucking at lower RPMs and cooler temps . it stops if i make the truck downshift or the truck gets up to operating temps (See post in motor problems forum).
EGR delete
Studs wOEM gaskets
blue spring
Zoodad
CFM largemouth
CTS Monitor W/egt
FICM replaced
STC replaced
HPOP replaced
IPR replaced
dpmac83 is offline
