Fire ringed heads? - Ford Powerstroke Diesel Forum
post #1 of 27 Old 02-26-2013, 07:40 PM Thread Starter
Quoted: 13 Post(s)
Fire ringed heads?
Hey guys
I've been planning on installing a set of headstuds but have been debating on weather or not getting the heads fire ringed Is something that needs to be done. The truck currently has a Afe intake, 5 inch straight piped exhaust and a SCT with a Edge CTS monitor. Thanks for any advice
Workman6.0 is offline
post #2 of 27 Old 02-26-2013, 07:43 PM
ZMANN's Avatar
Quoted: 1673 Post(s)
no it's an unnecessary expense IMHO
a good set of checked heads ,ARP's and OEM gaskets are what you need
We Miss you Ronnie
ZMANN is online now
post #3 of 27 Old 02-26-2013, 07:49 PM Thread Starter
Quoted: 13 Post(s)
Thank you Good to know,
By the way does anyone know of any shops near El Paso that do good head work?
post #4 of 27 Old 02-27-2013, 02:48 AM
Gearhead2012's Avatar
Quoted: 3 Post(s)
Your heads will likely be cracked, 95% of them are. A good machine shop can install hardened seats...read the link in my sig. And, unless you plan on running 60+psi of boost, I wouldn't even consider o-ringing the heads. When its just the heads that are done it usually doesn't turn out well on 6.0's...the uneven clamping of 4 head bolts per cylinder compared to the 6 head bolts per cylinder of a 7.3 or cummins causes leakage issues unless the block is done too.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #5 of 27 Old 02-27-2013, 03:58 AM Thread Starter
Quoted: 13 Post(s)
That's good too know and the links very helpful
post #6 of 27 Old 02-27-2013, 06:33 AM
Bump To Pass!!
toren302's Avatar
Quoted: 1713 Post(s)
Re: Fire ringed heads?
95% huh...? Out of the last 7 trucks I have done at work only one head had cracks. I think we just hear more about the negitives than the positives. But be sure to have them checked for sure, and need to use a shop that has done a good anount of these.
toren302 is offline
post #7 of 27 Old 02-27-2013, 06:39 AM Thread Starter
Quoted: 13 Post(s)
Do you have any suggestions for a shop near El Paso,TX
post #8 of 27 Old 02-27-2013, 06:42 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I don't want to knock o-ringing the heads but I have yet to hear anywhere that this is both preferred and superior to just using OEM head gaskets and ARPs (what I consider the gold standard for 6.0 head sealing). Considering the highest HP 6.0s only have this done. Just something to consider.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #9 of 27 Old 02-27-2013, 06:49 AM
Bump To Pass!!
toren302's Avatar
I dont sorry...call around to the local diesel shops and see who they are using. Thats usally a good starting point.
toren302 is offline
post #10 of 27 Old 02-27-2013, 06:50 AM
Fordmanalan's Avatar
I have seen a lot of guys have problems with fire rings because they could not get the clamping force they needed with just the 20 ARP's. the only success I have seen on the "O" ring is by splitting the difference and machining the head and the Block to mate together and keep the ring from moving during install.
OEM's, a good true surface on a head and ARP's is all you would need to hold unless youer going for 900+ HP
I currenlty have close to 600 on OEM's and ARP's
2006 F350, 6.0, CCSB
ARP's, Pmax, CASS 190/100's, SCT SF3 Erics tunes, Swamps 58V FICM, DRP EGR Delete, NLF Intake Pipes, Flo Pro, DRP RR, Fuel Bowl Delete, P&P heads, DRP Fuel Sump, FASS 220 571 HP 35" Toyo MT's, 20" Fuel wheels, Bushwacker's, 08 Mirrors, O8 Rear, leveled, bilsteins, AMP steps, ROYALTY CORE GRILL
571 HP 1213 lbs ft torque
PROUD OWNER OF ONE THE FEW SHOPS IN THE NORTHWEST THAT SPECIALIZE IN THE POWERSTROKE ENGINE.
DIESEL WURX
LOCATED IN SRINGFIELD OREGON
541-868-6658
Fordmanalan is offline
