my MBRP exhaust sounds like garbage - Ford Powerstroke Diesel Forum
post #1 of 24 Old 02-26-2013, 04:00 PM Thread Starter
ok so i just recently replaced my stock straight pipe (cat and muffler cut out) with a 5 inch turbo back MBRP straight pipe. The stock straight pipe sounded good. The truck had that 6.0 crackle we all love. As soon as i put the MBRP on it sounds like crap. it doesnt have that deep throaty sound i expected and all 6.0s have. mine just sounds muffled and it doesnt rumble its just this ricer like sound that sprays out of the pipe. Even at 3500RPM it doesnt sound like my buddys 6.0 with a 4inch MBRP. His sounds WAY better I figured someone on here may have an idea, the guy who sold/installed the exhaust doesnt really know what to say. Its an MBRP aluminized 5inch turbo back with 6inch tip. I would have saved the $500 and left the stock straight pipe had i known it was going to sound like this.
2006 F-250 Lariat FX4
ARP studs, ITSX SCT wireless tuner with custom tunes from Vivian, EGR delete 5'' MBRP straight pipe with 6'' tip, Kelly Safari tires, Glowshift Gauges
Soon to Come Insight CTS, Pioneer AVIC-X940BT Navigation head unit
37chambers is offline
post #2 of 24 Old 02-26-2013, 04:14 PM
sprksonu's Avatar
i have the diamond eye 5" turbo back kit and LOVE it! tried to tell my buddy to get the same and he chose to get the MBRP 5" kit and i have to agree with you it sounds like complete CHIT.
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #3 of 24 Old 02-26-2013, 05:17 PM
colonel angus's Avatar
Quoted: 2 Post(s)
If i was in your situation i'd take off the tip and see if it's any better.
If you don't like it then your next recourse is to return it.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #4 of 24 Old 02-26-2013, 05:27 PM
sprksonu's Avatar
I really don't think taking the tip off will make that much of a difference.
sprksonu is offline
post #5 of 24 Old 02-26-2013, 05:33 PM
PickupTrucker's Avatar
D
I was going to say the same thing as him
but since he already said it I actually have a question: does the 5" actually make a power difference over stock straight pipe? with the amount of mods you have on your truck?
I like pickup trucks, I like Fords, I like Ford pickup trucks, I like Broncos, Diesel Noises and Hydraulics.
05 6.0L plane jane
4spd w/granny and OD as close as i can get to feeling like Im driving a dump truck without parking one at my house!
PickupTrucker is offline
post #6 of 24 Old 02-26-2013, 05:34 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1680 Post(s)
Speaking from experience here I have had Stock 4in AFE 4in straight piped and muffled. 4in bully dog duals. 5in MBRP with and with out muffler and most recently 4in to 6in stack. For some reason the 5in MBRP straight pipe doesnt sound all that good. I put a muffler in and it got better but quieter. The stack sounded the best but is hard on long road trips. I just got my MBRP 4in duals straight pipe kit toady and will putting in tomorow. I have to say out of all of them the straight piped duals add a whole nother level to the 6.0 sound. You could try putting a muffler in it and see but it will get quieter.
Edit: Wow I think I just relized I have a problem^^^
toren302 is offline
post #7 of 24 Old 02-26-2013, 05:42 PM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
This is the first I've heard about the mbrp 5" sucking... Now its back to the search for an exhaust.
MrOneEyedBoh is offline
post #8 of 24 Old 02-26-2013, 05:46 PM
Quoted: 2 Post(s)
The 4" doesn't suck and i don't think there is any performance gains from going to the 5"
I'd try anything that didn't cost me regardless of making sense or not. Remove the Tip 4 Million Chinese may just be wrong. Ricer Reference.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #9 of 24 Old 02-26-2013, 05:50 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
I think you're right
dhanna6powerstroke is offline
post #10 of 24 Old 02-26-2013, 06:08 PM
Bump To Pass!!
toren302's Avatar
Hopefully this set of duals is my last exhaust. It doesnt make it any better but some of those kits were used on CL. I just picked them up to try somthing diffrent.
toren302 is offline
