unsure what to do now - Ford Powerstroke Diesel Forum
Old 02-23-2013, 07:16 AM
So I was getting a back pressure code and truck was running rough and building more boost then normal at cruising speed along with large mileage loss. so I cleaned my ebp, iat, map, and maf sensors last night. Took the truck out and seemed to be running better. Was pulling a little less boost at cruise speed but still couple more pounds then normal. when I would hammer on it it would run great then when I let off and tried to cruise boost went to 0 and wouldn't build any when trying to accelerate gradually. Had to put truck in neutral and slow down a bit then put it back in gear and it was fine. Then this morning when i started the truck at 26 degrees it ran rough for a little bit. Not like it was doing before I cleaned sensors but still a good bit rougher than it had. Anybody have any ideas?
Old 02-23-2013, 08:02 AM
Did you clean the EBP tube all the way to the manifold? A lot of the problems are at the manifold joint. Your post reads like sticky vanes. What were your EBP readings doing? Also, can you read your vanes position PID? I recommend you clean your turbo.
Old 02-23-2013, 10:15 AM
Cleaned the tube and nipple very good. Was thinking about doing the turbo myself but not quite sure what all is involved. Definitely a little more willing to try after last night. Thing was pretty easy to work on. Hardest part was getting factory air cleaner assembly out. That thing is hateful. Lol
Old 02-23-2013, 10:59 AM
The air cleaner assembly is a one minute job it you take it out in one piece, rotating it up and forward after separating it from the intake tube. Installation is the reverse after putting the mouth in the holes at front clip.
There are lots of tips on the turbo removal, cleaning and installation. Pictures and videos. A big tip is to use magnetic sockets. Get a large tarp and fold it up to lay on the engine bay (I use a 20x30 folded to 3x5). Disconnect the batteries, just in case. On the installation, do a trial run on the correct position for the oil drain tube -trust me on this one! Note how it sits on the pedestal. You already have the updated oil drain tube. The toughest part is the installation, especially since you haven't done one before.
