Performance gains from deleting the EGR?
I understand the general idea of deleting the egr, (which I've ordered the parts w/ up-pipe), but are there any performance benefits to be had? Not reburning hot exhaust which would probably be low in oxygen etc.
The mechanic recommended doing the oil cooler also and wants 8 hours to bill me, is this about right? Thanks again guys! |
8 hours for an EGR delete and oil cooler install sounds reasonable to me. There is alot that has to come off to get to the oil cooler. It is recommended to put a new oil cooler in when doing an EGR delete because you already have most of the stuff off the motor anyway and you would hate to have to pay 8 more hours of labor for an oil cooler install a month or two down the road. As for performance gains, I couldn't tell any gain in power or mpg with my EGR delete. I did notice that the motor seemed to run smoother and idle better.
I did my EGR cooler delete in my driveway in 4 hours. I am a backyard mechanic and know my way around motors and what tools to use, but it was totally new teritory for me when I started messing with this. The biggest thing that I noticed was that the motor seemed to run cooler, and takes longer to heat up in the winter (it seems I have to drive further down the road to get heat and on the coldest days there's spots on my windshield that don't melt the ice). It doesn't to idle any different though.
Dene |
First really big job I did on the truck did it in a weekend not that bad slow and steady and you can save a few bucks
No performance gains with the EGR delete, just engine longevity.
It will take 8 hours to do the EGR delete and oil cooler replacement. |
I would also add the fact that 05-07s EGR up pipe has a diverted scope in them that can hinder exhaust flow. Will you notice the difference, I doubt it, but it can't hurt.
Very good point! every little bit helps
Thanks |
