Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Performance Parts Discussion
Old 12-21-2007, 01:51 PM
dmbrichie dmbrichie is online now
Drilling the Exhaust Manifold....SCARED
Just wondering if I need a special drill bit to drill into the manifold for the sensor??? I see in the instructions it says to use a "size R" Tap or 1/8" Tap.. Not really sure if that is a special drill bit or can I just use a 1/8" metal drill bit??? I am thinking that once the hole is drilled in that the threads on the sensor will just thread itself into the metal, is that right??? Thanks guys...
Old 12-21-2007, 01:53 PM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
you can use whatever drill bit to drill the whole... but you will need a Tap to make the threads..... i believe its a 1/8th NPT pipe thread... i could be wrong... i know we had to buy one when we were installing a probe on Nicks truck..... i found it at a plumbers supply place... take your sensor to someplace like this and they will get you squared away
Old 12-21-2007, 01:54 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
No use a size R" drill bit (0.339") and then use a 1/8" NPT. You need to tap the hole don't try to self thread with the thermocouple
Old 12-21-2007, 02:04 PM
what he said lol.....
Old 12-21-2007, 02:09 PM
Also just another good idea is to use some high temp anti sieze on the thermocouple threads before you install just in case your thermocouple goes bad down the road you can get it back out to replace with a new one
Old 12-21-2007, 02:11 PM
thanks a lot guys...
Old 12-21-2007, 04:50 PM
tech10002 tech10002 is offline
The drill bit my tap took was a 21/64" . The tap will be marked with what size drill you need. But don't start out with that one. Start with a very small bit and keep going bigger and bigger until you get to the final size. That will keep the shavings small and greatly reduce the risk of breaking off a bit in the manifold.
I got my tap at Ace hardware. It's a 1/8-27 or 1/8 NPT. They are one in the same. It's a lot easier to just use an open end wrench to turn the tap. There's not really enough room in there to get a tap handle. Just tap a little at a time, and back out every couple turns to clear the shavings. Make sure your tap is well lubricated with some kind of oil. If you take it slow, you will have no problems.
These are the instructions pretty much everyone refers to for installing the probe: 3-Gauge Install Pictures
Old 12-24-2007, 07:56 PM
ShawnCT450R ShawnCT450R is online now
My machinist at work told me to use an 11/32 drill bit prior to tapping the 1/8" hole. Worked perfectly. Took a long time because I took my time and cleaned it out a few times. Drilled to hole in 5 steps, small to large, and ended up at 11/32. Find the long tap driver wrench or whatever it's called. Trying to get the tap started with a little wrench sucks. Good luck.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
