Looking for a new turbo - Ford Powerstroke Diesel Forum
Old 02-18-2013, 02:39 PM
Ok so my stock turbo is howling and I have oil build up in the hot side before the intercooler, so looking for a new one. So to me MTW looks like the best choice. The stage one is 775 vs an OEM for 950 or the powermax for 1200. Has any one ran the MTW stage 1? Would I have to get a custom tune for that turbo? Does some one have a different suggestion for a new turbo? My mods are 4in turbo back/w cat and muffler. I don't have an EGR delete but my thinking is just going to do it all the same time(EGR delete, tuner with gauges). I am going to buy a tuner with my turbo in case I need a special tune.
Old 02-18-2013, 02:41 PM
Re: Looking for a new turbo
I think the stage 1 is basically an upgraded OEM core....
I'm planning a hybrid and 175/75 in the near future
Sent from my DROID RAZR HD using AutoGuide.Com Free App
Old 02-18-2013, 02:42 PM
I would talk to Adrian and tell him everything you have on your truck he will help you out to chose a turbo that's right for you!
Old 02-18-2013, 02:50 PM
Actually the stage 1 is the same size as the powermax, so it is really a bigger turbo then stock. It is an upgrade to the orginal OEM turbo.
The stage 1 will run without a tune, in most trucks 96% anyway. I have had a few that needed tuning. Hope that helps out.
Old 02-18-2013, 02:51 PM
So to me it seems most of y'all like MTW. I really like new sticks but not sure if I can drop 3k or more lol. I'm looking to build a pretty tame truck. Plus has it's my DD can't be down much longer then a weekend.
Old 02-18-2013, 02:53 PM
Sweet thanks. Now the hybrid, what is that and would I need a tune for that? The hybrid vs the stage 2. Can I run stock infesters with out studs?
Old 02-18-2013, 03:06 PM
Better off calling me, and I can talk it over with you. 412-916-8091 Thanks
Old 02-18-2013, 04:02 PM
Sweet
That's why I said I thought. I wasn't positive.
Old 02-18-2013, 04:37 PM
Sweet
No big deal, was just clear things up.
Old 02-18-2013, 05:33 PM
Stage 1. Run with stock injectors and a tune of your choice. With a big tune, it will impress you. It impressed me and I have driven and flown some mightily impressive machines!
Studs are always a good idea if you plan on riding it hard. Unless you get larger injectors, you don't need a larger turbo, period. However, if you are thinking about it, having the larger charger is manageable with some tuning until you get the injectors.
As Adrian said, call him.
