I am on the fence - Ford Powerstroke Diesel Forum
post #1 of 14 Old 02-18-2013, 11:19 AM Thread Starter
jimmyz32's Avatar
Exclamation I am on the fence
I have blown my head gaskets again. I bought the heads used they where ported and decked. We put them on and used black onyx head gaskets now it is a year later and i have to do it again. 2 things we did wrong we used black onyx gaskets and i was not sure the heads where actually decked. So we are going to redo these again. Now i plan on running MTW stage 3 I was told i could get up to 50psi of boost I am heading to 600hp i was told with my setup i will be around 650hp so i wont be going any farther for more power. so if i just deck the heads and put factory gaskets in will it hold up or should i send them to Liberator and have them o-ringed? Please only answer if ya have experience with the set ups. there is a difference in o-ringing the heads for street use and fire ringing the heads and block for race use there seems to be a big confusion on those two on here. All my mods are in my sig. thanks Jim
2004 F250 4x4
1) head studs
2) 4" turbo back exhaust MBRP muffler
3) super expensive built transmission
4) leveling kit and 3.73 gears with a locker
5) Full EGR delete
6) Air Dog 2 165
7) full set of gauges
8) ladder bars
9) smoke switch (I Don't use it)
10) eliminated banjo bolts for 90 degree fittings
11) tuned by lots of people
12) ported heads
13) 190/75%
14)Powermax turbo
jimmyz32 is offline
post #2 of 14 Old 02-18-2013, 11:32 AM
Term3's Avatar
Quoted: 2 Post(s)
I am on the fence
Have a bud that blew HGs running 40-45 psi three times on OEM gaskets until he had his heads O-ringed. Yes, fire rings are NOT for a street driven truck.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 14 Old 02-18-2013, 11:38 AM Thread Starter
jimmyz32's Avatar
I run 35psi now with the powermax.
2004 F250 4x4
1) head studs
5) Full EGR delete
6) Air Dog 2 165
8) ladder bars
12) ported heads
13) 190/75%
14)Powermax turbo
jimmyz32 is offline
post #4 of 14 Old 02-18-2013, 11:50 AM
Superblazin's Avatar
I was told not to bother when Ellerton did mine! Stock head gaskets and arp studs ftw.
__________________
2005 Harley Edition CCSB, 30 over mahl pistons, delipped, bowled and coated, Carrillo rods, colt stage 2 cam, studs, a little head work, Custom intake, redneck compounds 66- s480, No limit intercooler piping, Elite diesel ZZ max intake manifold, 205cc /100% injectors, 150/150 Fass fuel pump, Regulated Return, Hellmans sump, CCV relocate, NADP Tranny, PhP ficm tune, Innovative Diesel custom tunes and some Redneck Lovin
Superblazin is offline
post #5 of 14 Old 02-18-2013, 11:56 AM Thread Starter
jimmyz32's Avatar
Superblazin, what kind of power and boost u making with the stage 4
2004 F250 4x4
1) head studs
5) Full EGR delete
6) Air Dog 2 165
8) ladder bars
12) ported heads
13) 190/75%
14)Powermax turbo
jimmyz32 is offline
post #6 of 14 Old 02-18-2013, 12:06 PM
Jury is still out on that. Lol I have a small boost leak to correct first before I Dyno. Hopefully by months end I'll have results
__________________
post #7 of 14 Old 02-18-2013, 12:23 PM Thread Starter
jimmyz32's Avatar
so u are running stock gaskets and studs that is it?
2004 F250 4x4
1) head studs
5) Full EGR delete
6) Air Dog 2 165
8) ladder bars
12) ported heads
13) 190/75%
14)Powermax turbo
jimmyz32 is offline
post #8 of 14 Old 02-18-2013, 12:26 PM
That's correct, the guy who built it for me sprays his over 1000 hp pas after pass with no problems. So I figured it was sound advice
__________________
post #9 of 14 Old 02-18-2013, 12:28 PM Thread Starter
jimmyz32's Avatar
well it would sure save me a ton of money. Then i can get my stage 3 sooner
2004 F250 4x4
1) head studs
5) Full EGR delete
6) Air Dog 2 165
8) ladder bars
12) ported heads
13) 190/75%
14)Powermax turbo
jimmyz32 is offline
post #10 of 14 Old 02-18-2013, 01:17 PM
Turbos = Witchcraft
TooMuch03's Avatar
Feedback Score: 3 reviews
I have to agree. I don't see the need to spend the extra money on o-rings. There are multiple trucks making much more power than yours will be using ARPs and stock gaskets. It may not hurt to upgrade your pushrods while you are at it, just for piece of mind.
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
