What kind of performance difference will I notice with a water/meth injection - Ford Powerstroke Diesel Forum
Old 02-13-2013, 09:19 AM
Just as it says
Sent from my SPH-L710 using AutoGuide.Com Free App
Old 02-13-2013, 09:21 AM
Feedback Score: 5 reviews
Depends on the ratio of meth I would say +- 25-50 HP
Old 02-13-2013, 09:25 AM
Re: What kind of performance difference will I notice with a water/meth injection
Guess I should say I have an 06 f250 ccsbfx4 studded deleted ficm tuned atlas 80 Looney wild factory exhaust straight piped turbo back I am looking to up grade quite a bit this year and was thinking water/meth and exhaust first then turbo and injectors mid summer
Old 02-13-2013, 09:46 AM
I would recommend exhaust, fuel system depending on the injector size, turbo and injectors, THEN water meth...
Water meth should not be first IMO, but rather when nothing else can be done as the icing on a cake
Old 02-13-2013, 09:50 AM
What he said ^ Why run it if you dont know if you need it or not! Its more of a cooling aid than anything!
Old 02-13-2013, 01:35 PM
My thoughts were from all the reading ive done anyone who has went with the hybird or stage 2 mtw turbo has noticed a jump in egts so I thought maybe do the watermeth and exhaust then the turbo kinda skip the egt problem idk im still learning so bare with me
Old 02-13-2013, 02:50 PM
I'm in the exact same place, have a Hybrid 175/75's and it's smokey leading me to believe it's running hotter than it could/should be. So spend 1500 on a stage 3 or 400 on H2O My Gosh Kit and kill 2 birds.
I"m waiting on the new H Wheel and after that if we can't make the 05's create 30's Boost PSI go with the Devil's Own Kit.
Denny
Old 02-13-2013, 03:08 PM
My hybrid is making EASILY 35++ psi boost with Tony's xtreme tune and tow tune WITH a big up pipe leak!
It's not smokey anymore with a few tune tweaks, AND cruising 60-65 mph my EGT's are now 600-650.
FYI I'm running 175/75 injectors
Old 02-13-2013, 03:25 PM
Denny
The water/meth isn't going to cure the smoke, only your foot, less fuel scheduled or more air will.
