Break in process??
How long is the break in process is needed after studs, gaskets, egr delete, and MTW Hybrid turbo???
Sent from my DROID RAZR |
Since you haven't really changed much, there is none. However, you would still have to purge your HPO system, that could take as little as 30 minutes or much longer if it is slow to purge. Your transmission and VGT will go through a learning cycle. The VGT and PCM will not take very long, but the transmission may flare for a while on shifts. It should all be happy within a hour or 2, but it could take longer.
Of course from the title he could have meant:
It takes about 5 seconds with a small hammer to break the door lock and pull the opening wire with your finger. If you have the ignition/steering wheel breaker, another 5-10 seconds. The longest part is waiting for the glow-plug start light to go out. Crank it over and its broken in and gone in less than 60 seconds!
Re: Break in process??
Well its running but I have a massive exhaust leak from that dumb y-pipe to the turbo from the manifolds, but even with that should I be reading boost on my edge??
Where is the leak? Most of the problems happen at the turbo to Y-pipe connection. Some times it looks close enough, but it has to be seated or it will leak. As you probably already know, it may have been a PITA to line it up the first time with all that room to work back there. Last edited by twoicebergs; 02-12-2013 at 11:06 AM. |
Took it for a drive down the road got on her a little and still reading a 0!!! WTF?
Did you forget to hook up the MAP sensor line that goes from the upper firewall on the passenger side above the evaporator housing down to the intake manifold on the passenger side to a copper barbed fitting sticking straight up?
Sure did haha
Such a small little hose!
