Best intercooler - Ford Powerstroke Diesel Forum
Old 02-11-2013, 04:21 AM
Best intercooler
So i think im going to replace my stock intercooler. wondering what the best one is. I have been thinking about using the banks since it comes with bigger piping and a high ram intake which i do not have at this point but i am not opposed to any other brands.
Old 02-11-2013, 02:11 PM
I have banks and it works great, quality kit.
Old 02-11-2013, 06:45 PM
No complaints with my Banks. A lot of members dis Banks stuff, but IMHO the intake filter, Intercooler and high ram intake are all quality made products. What makes mine great is that I bought both kits out of salvage for real cheap and the stuff was all like brand new!
k
Old 02-11-2013, 10:20 PM
The bigger pipes of the Banks are a drawback as you loose velocity of the air charge. Personally I think the design of the Banks elbow stinks, I'd get a Spearco.
Old 02-12-2013, 12:33 AM
Unless you're towing or making HUGE boost (50 psi+), then the OEM intercooler is going to be just fine. I bought a Banks techni-cooler and plumbing for my 2003 used. The fit and finish was great, but I don't tow enough to justify buying it new.
Unless you open up the hole in the intake manifold, a larger elbow means NOTHING! If I had done more research, I would have left my OEM intercooler in place and run the No Limit plumbing to clean up the air flow into the intake.
Here's the bottom line: DO NOT buy an aftermarket intercooler if you are looking for SEAT OF THE PANTS PERFORMANCE GAINS. If you are, then you are in for a let down. A larger intercooler on these trucks is like a bigger radiator in your hot rod, it's good for cooling (lower EGTs) when you're on the loud pedal and that's about it.
Old 02-12-2013, 03:17 AM
meaning No Limit Diesel here in Illinios?
Old 02-12-2013, 04:53 AM
Turbos = Witchcraft
The spearco is a nice unit. hellman intercoolers are also supposed to be good. the larger piping on the Banks is not needed. I have never had a problem with mine. I remember someone doing a test comparison a long time ago and finding that the spearco had quite a bit more pressure drop across it than the Banks intercooler did.
Old 02-12-2013, 07:52 AM
Yep I replaced my CFM+ Largemouth and pipe with the No Limit CAC. That is really the best Cold side solution out there.
Yep, Mike does a good job with these and will build in any additional bungs you may want for a water/meth setup or boost reference etc.
Old 02-12-2013, 07:55 AM
I haven't seen that Adam. If you find a link I'd be interested. The AFE Bladerunner is supposed to be a nice unit too but it is actually a bit smaller than the others.
Old 02-12-2013, 08:09 AM
Turbos = Witchcraft
I have been looking, and I can't for the life of me remember where I saw that I guess I will keep looking lol
Also, we can't forget about the Mishimoto intercooler. It is smaller too, but still works good.
