easy CCV mod question - Ford Powerstroke Diesel Forum
Old 02-09-2013, 03:39 PM
Im getting some mixed signals on the CCV mod. Do you or dont you or not reeley, need to have a catch tank of some sort for the CCV mod? Thanks
Old 02-09-2013, 03:46 PM
I Love Workin On Hotrods
You in NO WAY need a catch can to successfully run a CCV mod. I have never seen a drip from mine in 20k miles and in temps as high as 110F with 215F oil temp.
Old 02-09-2013, 03:54 PM
Thank you sir! I was gettin all worked gettin ready to buy a little tank.
So just leave the hose open or run a small filter set up?
Old 02-09-2013, 03:57 PM
Yea I just leave the hose open but if you want, you can run a little filter. There is no need for the filter though.
Old 02-09-2013, 04:04 PM
Thank you, as usual it looks like I was about to over think things
Old 02-10-2013, 04:08 AM
Just make sure the entire run of hose is downhill. Or supposedly oil will accumulate and make a plug causing oil to find your weakest seal. I have mine run in front of the fuel tank, there is a spot you can wedge the end in and hold it, been like that for 16k and no trouble.
Old 02-13-2013, 06:44 AM
Re: easy CCV mod question
If anything buy one of those aluminum water bottles from the dollar store and modify that for a catch can. I believe a 3/4 npt fitting will screw into the top...
Sent from my SPH-L710 using AutoGuide.Com Free App
Old 02-13-2013, 07:12 AM
I have not seen where a catch can was EVER needed with the CCV mod in my truck. I run mine straight down and I have yet to see a drop from it hit the ground.
Old 02-13-2013, 07:27 AM
I ran clear tygon tubing on mine just so i could see if any oil was accumulating.Had one low spot that did accumulate oil after fixing it did push the oil out but havn't seen any since
Old 02-13-2013, 07:44 AM
mine just runs down the truck and vents to atmosphere. never had a drop.
