BulletProof EGR Cooler vs. Delete - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-07-2013, 05:26 AM Thread Starter
usmcknight69's Avatar
I want to hear your opinions as to which one and why. What are the Pros and Cons of the cooler vs. doing the full delete? I would also like to hear from anybody that has had problems with doing one or the other! I am debating on which one I want to do.
***MOLON LABE***
2005 F250 SCREW LARIAT 6.0L
ARP STUDS, GASKETS, SCT CUSTOM, AFE STAGE II
10" LIFT, 38X14X24 KUMHO MUDDERS
MKW WHEELS, AMP RESEARCH STEPS
4:56 F/R GEARS, 5% TINT, CLAYMORE HITCH
PHANTOM II VOLTMETER, BOOST, EGT
TRANS TEMP, 2 12" KICKER COMP SUBS,
PIONEER AVIC Z130, RECON TAILS, 3RD BRAKE &
CAB LEDS, HID 6000K HEADLIGHTS & FOGS
UPFITTERS, EXTANG REVOLUTION LO PRO, MBRP DUALS
W/O CATS
usmcknight69 is offline
post #2 of 3 Old 02-07-2013, 06:39 AM
I did the BPD cooler because I didn't want to limit resale options, I don't plan on selling any time soon but you never know. I like the idea that no matter what happens down the road I have the parts and can pass emissions testing wherever life take me. I also never had any plans for tuning or power gains and wasn't looking for performance, just reliability, although...now the ORG has infected me and if I were to do it over I might do it differently but I'm really not sure. For the foreseeable future mine will stay as is, maybe if I'm in doing studs I'll delete it then but how knows.
If you're not concerned about where you can and can't sell the truck and don't have to pass emissions testing I'd delete it.
2005 - Excursion - Eddie Bauer - 4x4
185amp DC Power Engineering alternator
BPD oil cooler and cold weather package
Updated standpipes and dummy plugs
Edge Insight CTS with fuel pressure
No more STC fitting in the HPOP
Updated fuel pressure spring
Updated turbo oil drain
Updated turbo oil feed
Sinister Coolant Filter
BPD 58V FICM
Dual Batteries
Rotella T6
CAT ELC
The best 6.0 advice I've ever seen...
Fishermedic is offline
post #3 of 3 Old 02-07-2013, 07:04 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Ive got the BPD upgraded cooler and if/when I could do it over Ill be deleting the egr totally. I have no concern with the quality of the equipment. Cooler is very well made, but its still dumping junk back into the motor and is degrading the quality of the oil prematurly. I want to run a bypass filter on the truck soon which will help but reeley until I delete the system 100% Im kinda pizzin money away on filters. Plus you still gotta take the time to pull the egr valve once in a while and clean that....
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
