175/75 injectors Opinions Needed
Alright guys, I am currently running Casserly 155/30 injectors and a MTW Hybrid turbo. My truck runs really strong. However, since the recent cold snap, I have noticed some really bad stiction on cold starts. I have ran some TCW3 through a couple tanks and it seems to have helped some but it's still pretty bad. I admit these injectors have been ran with low fuel pressure alot of times so it doesn't really surprise me that I'm having an issue. The whole point of this thread is that I talked with Full Force today about rebuilding and bench flowing my injectors and possibly turning my 155's into 175's while they have them. (Can't ever have too much power, right!?). Bottom line; they can fix my injectors and make them 175/75's for roughly $1100. I couldn't get in touch with Warren to compare prices but I saw on their website they want $1625 for 175/75's. Do you guys think it would be worth it to step on up since I will have the injectors out anyway? How good will they match up with my hybrid? Should I use Full Force again?
Sorry for getting long winded. Thanks for the replies in advance. |
try warren tomorrow i know he can do better than that and im sure you know how good of quality they are.
I plan on trying to get in touch with Warren again tomorrow before I pull the trigger. When I saw his pricing for making a stock injector into a 175 I just assumed it would be the same price.
Stiction isn't on the fuel side of the injectors. It's on the oil side. Running fuel additives won't change anything. Try running some 5W-40 synthetic with a dose of Rev-X or Archoil and see if that solves your issues before you drop a grand or more on rebuilt injectors.
^^^^ Yep. And Im running Warren 175/75's with a hybrid not enough air for these injectors. Im thinking about going to a Stage 3.
If you go to 175 injectors keep your 30% nozzles. I see you also have a PHP FICM tuner. Try dropping back to a 40 hp tune or all the way back to stock and see if that doesn't help.
As said stiction happens on the oil side. 5w40 synthetic and some Rev-X or Archoil AR9100 will help if it is a stiction issue. |
Honest if you have full force talk to ryan or matt. Round about price idea here, nozzles roughly 450-500 dollars, then he probably gonna modify the fuel n oil plungers so let's see roughly another 200-300 bucks where we at 700-800 dollars roughly give or take, you end up with new internal parts and warranty probably as well and his time n work put into it. Casserly is good folks man delt with him for over 8yrs. Like stated above its your spools valves that are having the issue, I just pull my own clean them n I'm fine.
I've always ran 5w-40 Rotella synthetic in it. I do need to get some Rev-x and try that. I have noticed the fuel mileage isn't what it use to be on the highway either. But I figured that had to do with whatever is making the injectors act up on cold start.
Mitch, what would be the advantage of a 30% nozzle instead of 75%? I haven't tried setting my FICM tuner back to stock yet. Didn't even think about that could have something to do with it. AllPro, thanks for that advise man! I wanted to hear from someone actually running this combo. I was kind of worried the hybrid wouldn't be enough because it doesn't even clean my 155's up on WOT. Last edited by Dirty_Stroke; 02-05-2013 at 07:04 AM. |
And baby steps are for babies! Get some real fuel into that truck ![]() Go 190s or 205s
Get in touch with Jesse before you pull the trigger. I am nearly positive he could do better than that.
