Sinister Y-Pipe - Ford Powerstroke Diesel Forum
post #1 of 31 Old 02-03-2013, 04:16 PM Thread Starter
Sinister Y-Pipe
Hey all,
I bought a sinister diesel y-pipe because my stock one broke at the flex joint. Installing it today and it's leaking at the turbo v clamp connection. When installing i had the turbo loose, up pipe connections to the manifold bolted but loose, and i went ahead an tightened up the v-band clamp, so as to get the best seal. Then i went ahead and tightened the up pipes and turbo and down pipe. But its leaking bad, you can hear feel and see the smoke. i took the clamp off and inspected and everythings even and thers maybe an 1/8th'' gap around.
Anyone else have this problem?! frustrating ...
motor-man is offline
post #2 of 31 Old 02-03-2013, 04:32 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Try loosening the bolts at the manifolds (as far as you can but still having the nuts attached), V-Band clamp, AND turbo mounting bolts. Then see if you can get the v-band connection to seal tight by tightening the v-band clamp. If you can get that part to seal, then tighten the connections at the manifolds, and IF you can, then put the bolts in the turbo to hold it onto the pedestal.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 31 Old 02-03-2013, 04:39 PM Thread Starter
hey nate,
what you described is what i did. manifold bolts in but loose, no turbo bolts, no down pipe, and i tightened the v-band clamp. How that did not seal it i dont know. I guess ill have to try again. I forgot to check how the connection looked with the new y pipe when i had turbo out. It seems like somethings just not right.
post #4 of 31 Old 02-03-2013, 04:56 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
Whats not right is the alignment of the flange on the turbo to the flange on the new y-pipe. It has to be perfect before the marmon clamp is put on and tightened down.
I had problems putting my new y-pipe in as well. Here is a link to that discussion and what I ultimately did to get it right.
Got any tricks for y-pipe alignment? Lets hear 'em.
Please
You could save the life of a sick child
NYC F-350 is offline
post #5 of 31 Old 02-03-2013, 05:26 PM
BACKYARDIGAN
Quoted: 4 Post(s)
Sorry man, didn't realize you had the turbo loose with the bolts out. If the turbo is on the pedestal, can you get the pipe into position, close enough so it appears, that it would seal if the v-band clamp were on it?? Or were you trying to draw the pipe into the turbine inlet?? I ask because if you can do what I mentioned, then it should seal. You just have to wiggle and hand align it while you tighten the v-band clamp. If not, then I've got nothing man. Hope this helps.
Nate
post #6 of 31 Old 02-03-2013, 06:25 PM Thread Starter
some good reading here thanks for the most part i have done everything the same
i snapped two pics here, seems pretty darn close to me...
Anyone have problems specifically with sinisters pipe?
Im starting to get pretty sore working on this thing lol wont get another chance till next weekend
post #7 of 31 Old 02-03-2013, 06:32 PM
BACKYARDIGAN
Quoted: 4 Post(s)
You're the first person I've heard of buy them. Not saying that no one has bought a set, but I haven't heard of them.
Anyways, can you tell where it is hitting that is keeping it from lining up properly?? It does look very close.
Nate
post #8 of 31 Old 02-03-2013, 06:47 PM
Quoted: 28 Post(s)
Is there any possibility that the wrap you have on it is interfering with the Mormon clamp on the back side...
Now with the alignment issue, I have had the same distance issue. I used the ratchet strap meathod to pull the y-pipe to the passenger fender.
06 350 CCLB
Edge CTS
Up-Pipes by Cutting Edge
ARP's
Bulletproof EGR Cooler
Coolant filter
rentstdi is offline
post #9 of 31 Old 02-03-2013, 06:49 PM Thread Starter
No i cant really tell if it is hitting or where it is hitting.
post #10 of 31 Old 02-03-2013, 06:50 PM Thread Starter
No i know the heat wrap isn't interfering at all. Ratchet strap eh around the y pipe and hook it to where? lol
