SCT SF3 Canned Tunes - Ford Powerstroke Diesel Forum
Old 02-01-2013, 03:09 PM
I recently purchased an SCT SF3 for my 03 6.0. I am waiting on the custom tunes to come back so I am running canned tunese right now. Whether the tune is performance or street once i hit about 3K rpm it feels almost like I am hitting the rev limiter. If i just stop on the pedal it still feels like something is missing or bogey. Has anyone else ran into this?
the only performance I have done is a straight piped exhaust
Old 02-01-2013, 03:29 PM
First of all, nice name. The rev-limit on the SCT might be at that rpm. You can adjust that in the settings.
Old 02-01-2013, 03:51 PM
That was my first thought, I checked that and it was set at 4 so I changed it to 4.5 and maybe that helped not really sure. I bought the truck used so I am assuming the axle ratio is stock but I am completely stumped whats going on and SCT tech support sucks
Old 02-01-2013, 03:55 PM
Feedback Score: 3 reviews
How's the health of your HPOP? In stock tune, what is the max ICP psi you are seeing?
Sent from AutoGuide.com App
Old 02-01-2013, 03:57 PM
The truck will take some time to adjust to the new settings. Just give it some time and don't hammer on it for a while. Drive conservatively for a day or so, the computer and trans will relearn and you should be fine.
Old 02-01-2013, 04:03 PM
Sorry rookie here what is HPOP? Gauges being installed in the morning. I know the ICP sensor is good and when i run diagnostics nothing comes up
Old 02-01-2013, 04:11 PM
High Pressure Oil Pump, a weak or leaking HPOP will also cause low or limited upper end power.
Most OBDII monitors will show ICP psi readings.
Old 02-01-2013, 04:13 PM
Do you have a way to monitor/data log ICP psi or ICPv?
Old 02-01-2013, 04:20 PM
the sct sf3 has the data loggin option just have not used it yet...sitting in a freezing vehicle sucks but its in the garage tomorrow so i can check that out. As a stock vehicle the truck runs great btw
Old 02-01-2013, 04:37 PM
Not sure if SF3 lets you read any ICP readings.
When running any tune, your truck will show its weak points that weren't noticed in stock tune.
Some tune writers (not sure about the canned tunes) fool the ICP psi in order to get more power out of the truck. The fooled ICP parameter will show up on a OBDII monitor as being low because that is what the tune in letting the PCM see. This is why I said to check it in stock tune. You can check the HPOP health when running a tune in the PCM, but you will need to monitor the ICPv reading and convert the ICPv to ICP psi. The tune writers don't show a false ICPv thru the OBDII, so the ICPv will always be true.
There is another way to read true ICP psi, you either have to have a analog gauge or DashBoss ICP Calc PID.
