Anyone Towing With IPR Remote Oil Cooler? - Ford Powerstroke Diesel Forum
post #1 of 44 Old 01-31-2013, 06:33 PM Thread Starter
5fifty's Avatar
Look to hear from anyone towing 15-20,000lbs running the remote oil cooler setup. How are the temps, any information would be great to hear.??
Trying to get some feed backfor my upcoming build.
Thanks in advance..
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #2 of 44 Old 01-31-2013, 06:54 PM
portcity_gt's Avatar
Quoted: 1213 Post(s)
I havnt towed with mine yet, but my race car trailer is only about 10,000lbs anyway.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #3 of 44 Old 01-31-2013, 07:15 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Nothing against Nick here as he has this kit installed in his truck, but OP if your gonna do a remote oil cooler kit go with BPD as its been proven time and time again and has the data to back it up whereas Vince wouldn't release a single shred of evidence on his kit that proves it maintains OE specs for the oil system. There is about a 28 page thread called which remote oil cooler I suggest you read before making the choice to go with IPR's remote oil cooler it.
Just FYI if Vince would have defended his products and proved or gave some evidence that his kit maintains OE specs than I would recommend it as a semi-alternative to members that are on a strict budget that can't afford a complete fix all solution at the time of their repair/build. But seeing as how he didn't defend his product at all or prove it has been tested thoroughly and proves it works I simply cannot in good conscience recommend it to people as even a temporary band-aid as I have no proof it really works the way he says it does.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #4 of 44 Old 01-31-2013, 07:29 PM
Snake's Avatar
Quoted: 46 Post(s)
Search the site and make an informed decision about your upgrades. Ultimately, the choice is yours. But at least you did your due diligence.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #5 of 44 Old 02-01-2013, 06:07 AM
I would have mentioned the bpd vs. ipr stuff. BUT the op asked a question about the ipr kit, and I felt that's all that needed to be answered.
post #6 of 44 Old 02-01-2013, 06:20 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
I understand Nick. Like I said my post was not meant to be a bash against you, IPR or Vince just informing the OP to take a look around and research it before making a decision that's all.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #7 of 44 Old 02-01-2013, 07:21 AM
I didn't take it as bashing.
But for all we know the op may have already bought the ipr kit, I try not to assume anything and just answer the question at hand.
post #8 of 44 Old 02-01-2013, 09:55 AM Thread Starter
5fifty's Avatar
I did...I've read all 87 pages of one post and many others on here as well. I've spent as many hours as possible researching the web for as much info as I could gather in my spare time (lol, whats left of it, ask my GF and Son) My time is limited due to being an owner operator, hard to run an excavator and loader work all day, repair , maintain both pieces of equipment , office, work and,estimates by myself and raise an 8 yr old. Not many hours left in the day.
As with my heavy equipment I research as much as possible to make the best informed decision.
This upcoming build is brought on by needing some repairs on the 550 which mainly pulls my equipment all over FL. I want to repair and upgrade as much as possible while I am in here. Money is tough to come by these days and I am lucky to be able to do this all at once. I want to make the best decision for my dollar spent!
My normal load is around is any where between 15K-20K which is probably more than most people on here usually pull daily. That was my reasoning for directing the question to actual IPR users that might be pulling weight to get feedback.
I even took the today off to research, and order other parts.. It is nice to B your own boss most of the time..LoL
Kelderman Air Ride
PMM EGR Delete
5fifty is offline
post #9 of 44 Old 02-01-2013, 09:59 AM
Quoted: 5 Post(s)
Feedback Score: 3 reviews
IMO I would either go BPD or flush your system really well and put a factory oil cooler back in. Save your 1500 extra dollars for other upgrades or mods.
Good luck!!
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #10 of 44 Old 02-01-2013, 10:00 AM Thread Starter
5fifty's Avatar
I don't have an IPR kit yet, again my reasoning for directing my question as I did.
I've read about people running them on their DD trucks riding around town, interstate etc... But hope to hear from someone that tow weight often (more than a dirt bike LoL)
I'd ask around town, but not many people around here mess with their trucks, I mean come on it's Venice FL, average age is 70.. LoL
Thanks for your input, read your info is other posts BTW
Kelderman Air Ride
PMM EGR Delete
5fifty is offline
