Economy Tuner
Looking to get an economy tuner for my 04 F-350. I deleted the EGR cooler (but left the EGR in to avoid engine codes), my cat is deleted and so's the muffler. I'm getting 17mpg now with the hubs locked in and have had over 18mpg with them unlocked. I'd like to get over 20 with the truck since it's now my work ride (500 miles a week). I'm hoping to get something quality and inexpensive.
If you are going to tune it, FIRST get a monitor (Edge CTS Insight, Scangauge, Dashboss) which you should already have if you are a 6.0 owner. They go hand in hand. If you have passed that step, then you should know that custom tunes are the way to go for these trucks. A higher HP tune usually will yield the best economy if you can keep your foot out of it. It's so tempting not to though when you can spank muscle cars
Hopefully that helps. To recap, Monitor (with EGT of course), then custom tunes via SRL Gearhead, Loony Vivian, Xtreme Street Innovative, etc.
As stated above, a monitor and custom tunes will be the best way to go. Although, you should never EXPECT mileage gains out of a tune. Most people who expect huge gains for mileage are disappointed. An increase of 1-2mpg is usually what people see if they stick with their normal driving habits. Most people are not able to do this however, because of the added power they feel they must use.
The way I like to tell people to look at it is like this... You should see about the same mileage with A LOT more power. As far as what monitor and tunes to get... We offer a couple different SCT options, but the unit I would recommend is our Infinity. It is one unit that will do it all. It tunes, monitors PID's(generic and Ford enhanced), reads/clears DTC's, datalogs, plays media, has user controllable high/low alarms, and much more. Check out all of it's benefits HERE. If you have any other questions I would be glad to help you out. |
Does the unit have the capability to tune the transmission too? Save the stock file just in case? Todd |
Re: Economy Tuner
Economy Tuner
Sent from AutoGuide.com App Last edited by Lilpooh; 01-28-2013 at 11:56 AM. |
Todd |
I would strongly suggest looking at the SCT Livewire TS.!
It is a monitor AND a tuner in one unit. IMO it beats everything else by far now ![]() Get some custom tunes on that baby and that is all you need
Yes, the unit/our tunes will tune the transmission too. And yes, the stock file will be saved. Our unit uses an external SD memory card unlike most other manufacturers products. This enables all of the information to be stored on a removable device, such as datalogs, tunes, and custom themes. The supplied SD card has enough memory to hold around 1 million tunes. This number decreases if you have a lot of datalogs and other saved information on the card. The unit was only released in October, so yes it is still new. Quote:
Also, we have not added the optional fuel pressure sensor and wiring on the website yet because we are still in the process of receiving all of them. The EGT is available right now though. That is correct. Last edited by Justin@DP-Tuner; 01-28-2013 at 12:05 PM. |
That is incorrect. While it has some good features, it is limited to what it can do. It does not have the ability to monitor enhanced Ford PID's, and it will only hold up to 10 custom tunes.
