IPR Coolant Filter Canister - Ford Powerstroke Diesel Forum
Old 01-26-2013, 03:39 PM
Send a message via AIM to F350CCFX4
Anyone have theirs leak here?
From my understanding this is where the Canister can be taken apart.
Mine was just installed and it's leaking right there. Anyone else experiance this?
Do I dare try to tighten it right there?
Any details on how the canister is supposed to come apart, including pictures would be apprecaited.
Old 01-26-2013, 03:42 PM
This is the thread I am using for the information posted above, but how the media comes out is not clear to me.
IPR High Flow Coolant Filter Not Another Bypass
Old 01-26-2013, 04:47 PM
I dont have much experience with this, but I think the mating joint is closer to the filter housing (where the round part meets the square part)
Old 01-26-2013, 05:17 PM
Either the gasket isn't seated right or it needs tightened. I had one do that and it just needed to be tighter.
Old 01-26-2013, 06:43 PM
the knurled portion you say is leaking, is where you seperated to clean the fliter, it is all o-ring seals. just give it a good hand squeeze.
Old 01-27-2013, 05:25 AM
Yes, I talked with Vince and was able to get it apart using strap wrenches. It is a metric o ring, but the specs were not available at the time I was speaking with him. It was late Saturday, so that is more then understandable.
Hoping to get the specs from him at the latest Monday, so a new one can be purchased and the truck can be put back into service. Until then I am sitting and waiting. Can't make money sitting.
Old 01-27-2013, 11:36 AM
He told you he couldn't spec the o-ring? That doesn't sound right. Ask him for the o-ring supplier and have them spec it.
Old 01-27-2013, 11:37 AM
He said the specs were at his office. I understand that as it was about 6pm CST on Saturday.
Old 01-27-2013, 11:39 AM
Now that makes sense!!
Old 01-27-2013, 12:52 PM
Are you sure it's leaking from there and not just following that path? What I'm getting at is I see you have it mounted upside down, if the fittings were leaking it would flow down the canister like that.
