Dashboss installed...do I have a FICM problem? - Ford Powerstroke Diesel Forum
Old 01-25-2013, 05:00 AM
I finally got my Dashboss last night and it's awesome. I sat out in my truck in 14 degree weather just tweaking the gauges, etc. It was freezing but worth it. Anyway, I saved a log file of probably less than a minute, but during some testing before that, I noticed my FICM would briefly drop in the 45 range. However, during the time I did record, it never went below 46.5. Do I need a new FICM? The truck was running during this test.
-Log data removed for ZMANN-
Old 01-25-2013, 05:11 AM
U never even hit 48? I wld say it's looks to need repair
Sent from AutoGuide.com App
Feedback Score: 3 reviews
Dropping to 45v right after a cold 14* temp start up, while glow plugs are running could be batteries on the weaker side.
I would get the batteries load tested first to see if they are in good condition first. Most chain stores provide this service free. If the batteries test out good, might want to check into a new or repaired FICM.
Old 01-25-2013, 05:21 AM
I'd be monitoring the FICM but at those extreme temps I wouldn't freak
most FICM's seem to start to fail with a low output when cold then eventually climb after a while
Old 01-25-2013, 05:28 AM
Ok, I never did move off the spot, so I thought I'd try to monitor it while driving to see if it made a difference. At least it's not hovering at 42v or something constantly. I'll keep an eye on it. Thanks for the input. I've heard of Swamps and Ed at FICMrepair.com. Would those be the guys everyone recommends?
I should add that all last weekend, I let the batteries sit on the trickle charger and I had the block heater plugged in for 6 hours before I fired the truck up. I had the whole log file added, but it was so much text and I hated to be a tool about it, but there is nowhere to attach a .csv file and I don't feel like uploading a pic of the spreadsheet log file.
Old 01-25-2013, 05:35 AM
mine was hovering around 42 for the first 20 minutes so I went with the bullet proof 6 phase
the repairs are ok but it still can fail again so I went with the improved version since I keep my stuff for a long time
Old 01-25-2013, 05:37 AM
well thank God because that firs log was bad enough LOL
Old 01-25-2013, 05:40 AM
There ZMANN, I cleaned it up for you
Old 01-25-2013, 05:47 AM
LOL!! I still haven't figured out how to attach PDF files to a post, or even figure out how to convert the CSV files to PDF!
Old 01-25-2013, 05:48 AM
LOL thanks it made this thread 1/4 as long
