Head Stud and Gasket Restart - Ford Powerstroke Diesel Forum
Old 01-23-2013, 01:34 PM
I just got done installing ARP head studs,Inner Oil Cooler,OEM Gaskets,EGR Delete. I have searched this forum and others and can not find the answer. I got the truck fired up and running but there is a popping sound coming through the intake.I have checked rockers,push rods,injectors. Is it possible that there is air in the lines causing this? Any and all suggestions are welcome. I forgot to mention is a 04 F-250.
Old 01-23-2013, 02:34 PM
should not be ANY popping... something is either loose, leaking, or binding
Old 01-23-2013, 02:42 PM
MAD - Modification Addict
Feedback Score: 7 reviews
Bent push rod.
Old 01-23-2013, 03:13 PM
Re: Head Stud and Gasket Restart
Were the heads checked/new? Could be a bent valve or bad push rod.
Sent from my SPH-D710 using AutoGuide.Com Free App
Old 01-23-2013, 03:45 PM
No bent push rods or bent valves, or broken rockers. Took everything apart and double checked. I think the injector copper rings are smashed on an injector.?
Old 01-23-2013, 03:47 PM
Yes the heads were checked and machined. Also new injector cups and valve guides were installed.
Old 01-23-2013, 03:51 PM
I would say a bent push rod or broken rocker. I had the same problem.
Old 01-23-2013, 04:24 PM
Double check number 5.
Old 01-23-2013, 04:51 PM
Did you get your heads machined?
Old 01-23-2013, 05:04 PM
How much was milled off of your heads, if it was over .008 were the valves ground also?
