Liberator Performance O-Ring Cylinder Heads - Ford Powerstroke Diesel Forum
Old 01-21-2013, 07:57 PM
Looking for some reviews from people that have been running the Liberator Performance o-ring cylinder heads.
this is NOT a o-ring VS non o-ring cylinder head thread so please dont say one is better than another.
I am looking for real life experience with guys that have had good or bad experience with these heads.
  • What other mods do you have?
  • How many miles do you have on them?
  • What do you use the truck for? Daily Driver? Towing? Race truck? etc.
  • What issues if any have you had?
share you experience with them as a company as well as your overall review of the product.
Old 01-22-2013, 05:37 AM
I have a buddy who has a set on his 6.0, not this brand but they are oringed. Its been that way for 5 years now with no issues.
Old 01-22-2013, 05:46 PM
Not really recommend in daily drivers. messed with a few trucks
Old 01-22-2013, 05:58 PM
can you please explain why they are not recommended on daily driver trucks? please elaborate on your experiences thanks!
Old 01-22-2013, 06:17 PM
Old 01-22-2013, 06:36 PM
cant say much from experience but did a set on two trucks they have maybe 15k on them since havent had any issues dont need them unless going above 5 or 600 hp. i would personally stick with just studs and oem gasket. just read alot on them not being good for daily drivers because of the heat cycles
Old 01-23-2013, 05:50 AM
I think your confusing o-ringed and fire ringed together. Fire ring is not really recommended for a daily driver, however o-ringed heads are just fine for that purpose. O-ring is a thin piano wire type of ring that is pressed into a precut grove in the cylinder head, a fire ring is a thick ring that sits in a grove cut both in the head and the block. So the fire ring will sit 50% in the block grove and 50% in the head grove. Its great for race trucks that will see over 60 or more PSI of boost regularly. O-ring heads are good for about up to 60-65psi on a 6.0 and more on a 6.4 due to the increased clamp load and are perfectly fine for daily drivers.
Old 01-23-2013, 07:21 AM
Re: Liberator Performance O-Ring Cylinder Heads
If you search the forum you'll find a build thread by a guy with screen name Dansomething iirc who did a build of his own using these heads and had good things to say. This thread is years old so getting an update from him could be difficult.
Old 01-23-2013, 07:40 AM
I Love Workin On Hotrods
So, aside from Liberator, who else does "O-ring" heads??
Old 01-23-2013, 07:41 AM
I have the liberator o ringed heads on my 05 harley edition f350. I use the truck as a daily driver and haven't had any issues. I bought the truck with a bad motor and had it gone through by a local shop that is well known for their performance work on diesels. They ordered the heads so I can't speak to customer service, but my shop spoke very highly of the heads themselves. Said that they can handle 50 PSI boost with no problem. I rarely get half that boost so I shouldn't need to worry. Again, I haven't had any issues with pulling an enclosed car trailer and using truck as a daily driver. Other mods that I have is an edge juice with att. 5" TB no can no kitty, bat mo wheel in the turbo, full bullet proofing with egr delete, s&b intake. I would think if you needed heads, go for it, if your heads are fine, just stud them.
