Exhaust Question
I just got my silverline exhaust installed today and i was looking at it when my truck got home and noticed oil in the tip....Is this normal or not? If not what could be causing it....Any help will be appreciated....
mine did that also its just moisture in the exhaust and the soot mixed
it had only been on there a hour....so there would be moisture in a brand new exhaust that has only been out of the box for a hour? I hope your right...If it was my turbo guess that means i could upgrade to the hybrid...
i wiped it all out and its there again and it really looks lke oil...any help
diesel creates soot and heat, heat and cold metals create moisture. moisture and soot look a lot like oil.
Alot of time its just oil that was sprayed in when the exhuast was installed, any oil from motor would burn up by the time it got that far back
ok thanks ....
