Need advice on performents parts - Ford Powerstroke Diesel Forum
Old 01-17-2013, 02:14 PM
Alright, first off i have a 2004 F350 6.0. I want to put a programmer, cold air intake and a bigger filter housing in the truck. Ive read a lot about edge, sct and banks tuners and ram airs but i am not sure on which is the best to have. I also am looking into a bigger exhaust, probably 5 inches. Any suggestions on what to get and run from?
Old 01-18-2013, 09:55 AM
Get your hands on an SCT w/ custom tunes and never look back.
Old 01-18-2013, 09:56 AM
7.3 4 Ever! Nothing else!
Feedback Score: 7 reviews
Get ARP's if your running more power!
Old 01-18-2013, 09:58 AM
get an sct and exhaust turbo back and be done with it. no need for cold air intake as it does nothing on these trucks till about 500+ hp
Old 01-18-2013, 10:02 AM
Send a message via Skype™ to kendallcschm
and head studs and EGR delete and coolant filter.. and if your set on a CAI... go with banks ram air.. from my experience it works great even before 500HP, just doesn't filter **** out of air as well as stock
Old 01-18-2013, 10:03 AM
I wonder were he could get some of those?
Old 01-18-2013, 10:04 AM
I wonder! I have them!
Old 01-18-2013, 10:41 AM
I would go with S&B long before I chose Banks.
Old 01-18-2013, 10:48 AM
Originally Posted by kendallcschm View Post
and head studs and EGR delete and coolant filter.. and if your set on a CAI cold air intake... go with banks ram air.. from my experience it works great even before 500HP, just doesn't filter **** out of air as well as stock
Pretty much sums it up.
SCT is going to be one of the best option for tuning. Take your pick of the preferred exhaust set up, but installing one is recommended. Coolant filter makes for a good preventative item as you will find out the more you poke around on here. S&B and AFE make the best kits for your intake. They are tested to be the best balance of air flow and filtering. The S&B will be a little cheaper.
If you want BIG horse power, ARP studs are going to be your friend.
Old 01-18-2013, 10:50 AM
Turbos = Witchcraft
Oh my goodness! You guys need to stop for a second. Just pull your heads out of your collective butts and make sure the OP has a healthy truck before we go spending all his money on parts. OP, GET A MONITOR FIRST! I like the Edge Insight CS or CTS or the scangauge II. Check you ECT/EOT delta and FICM voltage. Then get fuel pressure and EGT gauges so you know what is going on under the hood. There is sticky in this section about monitoring the 6.0. Read up on that before you do anything. This will be important when you do add exhaust and a tuner.
Tags
advice, exhaust, intake, powerstroke, programmer
