help me build a FICM... - Page 3 - Ford Powerstroke Diesel Forum
  #21 (permalink)
Old 01-17-2013, 10:28 AM
Re: help me build a FICM...
I took my truck to a shop and they hooked a scanner to it and said it pulled a "U" code and that i had the wrong ficm. Could that be from having a mix matched ficm like a 4 pin power supply match with a 7 pin logic board or 7 pin power supply matched with a 4 pin logic board?
Sent from my DROID RAZR using AutoGuide.Com Free App
  #22 (permalink)
Old 01-17-2013, 11:25 AM
Turbos = Witchcraft
Actually, I believe Innovative now sells a FICM tuner that you can buy, for like $350
  #23 (permalink)
Old 01-17-2013, 11:35 AM
According to Ed at ficm repair.com that the U1106??? (maybe remembering that wrong) anyway the U1106 code Incompatibility with ficm is nothing to worry about. I now have that after putting the 7 pin in place of the old 4 pin.
  #24 (permalink)
Old 01-17-2013, 12:33 PM
MAD - Modification Addict
Feedback Score: 7 reviews
YOU CANNOT MIX AND MATCH HALF SHELLS FROM A 4 PIN TO A 7 PIN FICM.
I just said this a couple posts up.
  #25 (permalink)
Old 01-17-2013, 12:52 PM
I read what you said. I was asking if this might of been done to my truck before i bought it and thats what was causing the u code. Did you mean that they wont bolt together?
  #26 (permalink)
Old 01-17-2013, 12:56 PM
They will not go together.
4 PIN.
7 PiN will have 7 holes and 7 screws where you see the 4 at above. They are incompatible.
  #27 (permalink)
Old 01-17-2013, 01:17 PM
Sorry if I did not make myself clear, I took the entire 4 pin Ficm out and replaced it with a completly diffrent 7 pin ficm
  #28 (permalink)
Old 01-17-2013, 01:49 PM
  #29 (permalink)
Old 01-17-2013, 02:09 PM
Almost anytime you install a FICM in the truck that has not been flashed specifically to that truck it will set that code.
It will not affect drivability or overall performance of the vehicle.
