FICM with Atlas 40 Tune is Awesome - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-16-2013, 12:32 PM Thread Starter
mdbreaux's Avatar
Tired of rough idle on cold starts? Tired of losing injectors every year or so? Check out your FICM with Autoenguinity or something else to determine if it is going below 48 volts EVER. Mine was going down to 43 and bouncing all over the place, rarely reaching 48. Talked to Ed at FICMrepair.com after discussing the issue with members in thisn forum. Got a rebuilt FICM from Ed with the Atlas 40 tune because I want to still tow my race car and the Atlas 80 and Hercules make towing more difficult due to higher EGT and I have stock tranny and converter and the higher tunes are hard on that too. Put it in last night and on cold start this morning (36 degrees without block heater plugged in) it started and ran so smooth it was hard to imagine. Also, my low end power is significantly higher, which is great for my 71mm billet wheel turbo. It bridges the gap with tht turbo on the low end. I can't say enought about it so far. I am ditching RevX because it only lasted 3 weeks and is simply too expensive to fizzle out that fast. Hopefully I will never need it again.
6.0 ARP studs, EGR and cat delete, Magnaflow 4", Precision 71mm BB billet wheel, methanol, 190cc Hypermax injectors, SCT tuned by Eric, Banks intercooler and intake, FASS fuel with IDP regulated return, BD Tial BOV
mdbreaux is offline
post #2 of 2 Old 01-16-2013, 07:01 PM
kcoyner's Avatar
Quoted: 74 Post(s)
If you aren't running a fully synthetic oil I recommend that you fill with that ASAP. 26K miles since my build and I still don't see a need and don't use a friction modifier.
k
2005 F-350 Lariat DRW, Asheville Engines Performance 20 Long Block with ARP studs and a Stage 2 Cam. EGR Delete. SCT tuner. Salvaged Banks High Ram Intake Elbow, Ram Air Filter and IC. Amsoil lubricants, Sinister Coolant Filter, Edge Insight CTS, SP Performance Rotors and Hawk Tow Pads, Motorcraft fuel and transmission filters, Mishimoto radiator, thermostat and silicone hoses. BulletProofDiesel water pump and Heavy Duty Oil Cooler. Marty's Diesel Regulated Return
kcoyner is offline
