PHP ficm programer question - Ford Powerstroke Diesel Forum
Old 01-15-2013, 04:31 PM
ok so i got my PHP in the mail today. My truck is currently throwing a code for FICM performance. I want to use the programer to check my FICM voltage. The question is can just plug it in to check the voltage and not reprogram anything? The instructions say to take out the relay or you will get damage and thats what worrys me. i do not want to reprogram just check voltage.
Old 01-15-2013, 04:39 PM
IU Hoosier Fan
Yes you can. You only take out the relay to program the FICM.
Old 01-15-2013, 04:43 PM
Feedback Score: 3 reviews
Yes you can check your voltage without pulling the relay or reprogram.
Going by memory here, plug in the gryphon, follow instructions about turning key on/off. You should come to s screen that has a list of what you want to do, check DTC, program, display, monitor, ect,ect. Scroll to the one that says display or whatever, hit enter button.
Just don't pick "program"!!
What is the code? U0306??
Sent from my iPhone using AutoGuide.com App
Old 01-15-2013, 05:02 PM
I think its a P0611 code. Just checked it and its 47 to 48 volts but its warm. ill check it in the morning. Batteries are only a year old and a brand new alt. ill check it cold. only does it when its not plugged in but if i can get a new FICM out of warranty im goin to since i only have a month left
Old 01-15-2013, 05:05 PM
IU Hoosier Fan
Your on the right track. Just make sure you check the voltage while cranking.
Old 01-16-2013, 04:36 AM
this morning it was 30 degrees the voltage in was 11.6 battery was about the same. voltage out jumped right to 45 then dropped to 32 after glow plugs warmed and droped to 30 while cranking and slowly started climbing.
Old 01-16-2013, 04:37 AM
Time for a new or repaired FICM.
Old 01-16-2013, 04:57 AM
I have that code also
but I have 58 volts at the FICM lol
get that ficm fixed asap
Old 01-16-2013, 05:02 AM
Isnt that just a FICM incompatibility code? Ive got a 03 ficm in my 05 and I get that code ( I beleive thats the same one )
Old 01-16-2013, 05:03 AM
the p0611 is a FICM voltage out of range code for Mine and the OP
