Turbo down tube? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-13-2007, 05:56 PM Thread Starter
Italian024's Avatar
Turbo down tube?
I was wondering if it would be a problem if I just took the cat off and let the exhaust exit right there under the truck or will it get too hot right next to the tranny. I have a 04 6.0 thanks
Italian024 is offline
post #2 of 6 Old 11-13-2007, 06:06 PM
Raul@Stealth Automotive's Avatar
if you put a pipe pointing it downwards you should be good... only thing that would concern me is soot all over the underside of your truck
Raul@Stealth Automotive is offline
post #3 of 6 Old 11-13-2007, 06:25 PM
DoubleDpsd's Avatar
no problems here.
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #4 of 6 Old 11-13-2007, 06:27 PM
dustindiesel's Avatar
i agree with raul..i have soot all underneith my truck...at least dump it downwards
2003 psd 6.0
red crewcab
16" suspension lift, 48" michelin xml's on 20x10 black rockstars, 6000k hid's, crossover steering, zoodad mod, ccv mod, modified up pipe to delete egr cooler,high idle mod, mbrp 3.5 downpipe, train horns(also on remote), diamond plate tool box, recon smoked cablights, Code670 alarm/remote start,100w reverse lights, oil-based underbody paint
**soon to purchase SCT rockwell 2.5 ton frt/rear
-8,520lbs with me in it
dustindiesel is offline
post #5 of 6 Old 11-13-2007, 08:02 PM Thread Starter
Italian024's Avatar
thanks guys
post #6 of 6 Old 11-15-2007, 09:51 AM
DieselViking's Avatar
Remember the soot can mix with water and form a mild acid, you don't want that on the underside of your truck. At least dump it down, or add an elbow to shoot it out the side. If anything I would periodically pressure wash the underside of the truck to remove soot buildup every so often.
"That which does not kill us makes us stronger"
"The only easy day was yesterday"
2006 F-250 SC 4x2 6.0
Isspro Pyro
Zoodad
High Idle Mod
Diamondeye 4" Stainless Turbo-back Exhaust
DieselViking is offline
