altrenate mounting for livewire ts
Found a decent location for the livewire ts on the dash next to the climate controls. My truck has a blank panal where the electronic 4x4 transfer switch would be. My first attempt to attach photos so I hope it works. The only thing I should have done different- raise the unit up a bit higher, top of the ts even with the bottom of the ac vent. View of the bottom LH corner of my gauge display is obstructed by the shift lever in drive. I drilled out a hole and placed the knuckle connector supplied with the TS in the panal. Secured with a drop of super glue. Drilled out a small hole along the panal edge and routed the connecting cable directly into the dash
