alrenate mounting for livewire ts - Ford Powerstroke Diesel Forum
Old 01-13-2013, 12:45 PM
alternate mounting for livewire ts
Found a decent location for the livewire ts on the dash next to the climate controls. My truck has a blank panal where the electronic 4x4 transfer switch would be. My first attempt to attach photos so I hope it works. The only thing I should have done different- raise the unit up a bit higher, top of the ts even with the bottom of the ac vent. The bottom LH corner of my gauge display is obstructed by the shift lever in drive. I drilled out a hole and placed the knuckler connector supplied with the TS in the panal. Secured with a drop of super glue. Drilled out a small hole and routed the cable direct into the dash
alrenate mounting for livewire ts-2013-01-13-12.02.24_plymouth_ohio_us.jpg   alrenate mounting for livewire ts-2013-01-13-11.27.59_kingsville_ohio_us.jpg   alrenate mounting for livewire ts-2013-01-13-11.19.07.jpg
Last edited by hvac man; 01-13-2013 at 01:22 PM. Reason: sorry for the double post
Old 01-13-2013, 01:33 PM
Looks like a great place for it....if you don't have ESOTF 4x4. I like it though!!
Old 01-14-2013, 06:35 PM
Looks Good
