Hopefully no permanent damage - Ford Powerstroke Diesel Forum
post #1 of 18 Old 01-12-2013, 06:41 PM Thread Starter
Brent Beeler's Avatar
Okay guys, so I have a non studded 2007 f250 running SCT livewire ts with IDP Xtream street tune. Earlier today I was going down the highway jumping on it pretty good highest EGT was maybe 1320 for maybe 1 second. When I got home I noticed a little coolant ran down the front spring area from the degas tank. I opened it and relived the pressure. I've driven it around a little since then (no hard throttle hits, just driving normal) haven't seen any more coolant under the truck since. My question is, could I have done any damage. If not what could it have been doing that for. Has anyone else ever experienced this? All temps looked good too.
Thanks Brent.
Sent from my iPhone using AutoGuide.com App
Brent Beeler is offline
post #2 of 18 Old 01-12-2013, 06:45 PM Thread Starter
BTW innovative diesel told me the Xtreme Street tune they sent me was safe for stock head bolts
post #3 of 18 Old 01-12-2013, 06:48 PM
Slacker
Evil Eye's Avatar
Quoted: 190 Post(s)
Feedback Score: 4 reviews
Could have just been some minor puking. How full is your degas bottle? It should be about 1/2"-1" below the full mark. (Mine is closer to 1" below). If I put more coolant in there, mine will puke it out.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #4 of 18 Old 01-12-2013, 06:49 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
What all is done to the truck modification wise? Also the 1320 EGT's is nothing I have hit over 1900* .
Try replacing the degas bottle cap with a new updated one. They are only $5. Also make sure your coolant level isn't to high. The new MAX line is the OLD MIN line.
Another thing is what are your EOT and ECT??
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #5 of 18 Old 01-12-2013, 07:11 PM Thread Starter
I am hoping that it was just a little minor puking, what would make it puke a little? I've never seen it do that before. I will have to look again to see where the level is I don't remember. EOT and ECT are no more than 5 to 7 apart at any given time. Thinking maybe I should get a new cap just to be on the safe side. SCT tuner, cold air intake, and turbo back 4 inch MBRP exhaust are the only mods.
post #6 of 18 Old 01-12-2013, 07:12 PM Thread Starter
Damn, how long did you hold it at 1900? no damage afterwords?
post #7 of 18 Old 01-12-2013, 07:18 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
LOL few seconds. Nope still running like a top.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #8 of 18 Old 01-12-2013, 07:48 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
You can usually run the temps up pretty high as long as you don't hold em out too long. Just because the "EGTs" are 1900F, doesn't mean that the pistons are over 1200F (point at which most aluminum alloys start melting). Doing a WOT run from like 30-100 mph is pretty harmless regardless of what the temps get up to because the amount of time the pistons are exposed to the heat.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #9 of 18 Old 01-12-2013, 08:02 PM Thread Starter
That makes me feel a little better, because I usually come all the way off the throttle as soon as I hit 1250*
post #10 of 18 Old 01-12-2013, 09:08 PM
BACKYARDIGAN
Quoted: 4 Post(s)
Yea there are guys who tow heavy and hold 1200+F EGTs all day long without a problem. I understand not wanting to hurt anything, but I honestly don't think you will if it is for just that short amount of time. Of course it would be better if you had studs but either way it's the pressures there as opposed to temps.
Nate
