Downpipe not moving
I have undone the clamp now what everythings out except dp The dp's not moving an inch what now.
The truck is 06 6.0 thanx.
It'll come off - I know it doesn't seem like it but it literally will pop loose. I've had to politely hit a few of them where I cut the pipe at the bend to 'convince' it to come loose.
There is a small clip at the 12 o'clock position. Just push/bang on the pipe from underneath in the upwards direction, should come out easy.
also if you cut the pipe after the DP so that you can help it move a lil it should pop right off...
