IPR Full Flow Coolant filter and EGR delete review - Ford Powerstroke Diesel Forum
post #1 of 55 Old 01-11-2013, 08:21 PM Thread Starter
I win....
cRaZy8's Avatar
Quoted: 47 Post(s)
Garage
Just finished putting studs, new oil cooler, EGR delete, IDP long y-pipe, blue spring, 6.4 banjos, and some other little items in my brother in laws new to him 2005 CCSB.
IPR coolant filter-
-nicely machined pieces
-flimsy bracket for filter housing
-cheapest of the cheap hose clamps supplied
-very minimal length of heater hose supplied, dont make a mistake
-hose clamps under turbo, feeding from oil cooler, are dangerously close to rubbing both the FICM & Engine harness. I wrapped them in slit rubber hoses for protection
-adding this protection made putting the turbo oil feed line back in place difficult
- no instructions at all, not even a crappy photocopy of pics
Overall I would score it 6 out of 10, before seeing how it performs.
IPR EGR Delete (no idea what version, too many to keep up with)-
-again, nicely machined parts
-no o-ring supplied for intake coolant passage to delete tube- WTF? reused the old one
-no hose supplied for oil cooler to egr delete tube- WTF? did the job in my shop, luckily I have 20 different kinds of hoses on the shelf for marine engines
-no hose clamps supplied
-no EGR valve block off plate- this bothered me the most, why wouldnt you have this in an EGR DELETE KIT?!
-no gasket for the EGR to intake block off (where EGR cooler used to bolt on), seriously? you cant even throw in a cheap aftermarket gasket? i used black hi temp RTV
Overall score 5 out of 10. If any parts fail at any point, my score would drop to a 2 (only because of the machine work bling).
Needless to say I am not that impressed by his products. The only reason we got his EGR delete was because XDP and numerous other suppliers were on back order, and I was in a bit of a time crunch. His price on the kit was more than everyone else also.
S362 68/.91
Irate SS T4
Holders 175/30
BPD FICM
BPD Cooler
BPD WP
ARP
Yukon Locker
4.30's
ODP St3 Manifold
NL CAI
Rudy's Intake elbow
PSP Coolant Tank
Mishimoto Rad. & IC pipes
EGR Del.
Edge CTS2
SCT X3
FICM Tune
Jugger Pump w/DIY RR
Fuel PSI Gauge
35x18's
Bilstein 2.5"
Trac. Bars
DC Power
Powerstops
USCG 50GT MMC
Yamaha Outboard Master Tech
cRaZy8 is offline
post #2 of 55 Old 01-11-2013, 08:27 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
These are the types of reviews we want to see. Have you discussed this with them at all? Sorry you had to go through that but thanks for the thorough review.
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
post #3 of 55 Old 01-11-2013, 08:40 PM
if you get in touch with them keep us posted
2004.5 Mods: CTS, Lots Of Gauges, 7 inch Stack, ARP Studs, Tuned by Eric, SAP Diesel Full Fuel System, WEP Ported Intake Manifold, Mechman Alt, BPD 6 Phase Ficm, BPD Oil Cooler, BPD Oil Bypass, Warren 350cc conventionals, SAP Diesel/Warren Diesel Twin Pump Kit, SAP Diesel Triple Turbos and SAP Diesel Trans in Progress.
g2shuck is offline
post #4 of 55 Old 01-12-2013, 07:45 AM
portcity_gt's Avatar
Quoted: 1400 Post(s)
I'm not sure what your motives are here, but I would like to reply to your coolant filter "review".
Yes machine work is nice
The bracket is twice as thick as the flimsy fender it's bolted to, the bracket is more than strong enough.
Did you expect t-bolt clamps?, mine came with nice thick clamps
I have the oil cooler as well so I can't comment on hose length because mine is a different setup
There is not a single wire anywhere NEAR the manifold
Nice clear detailed instructions are available via PDF, all you had to do is ask, they would have been emailed to you.
I don't have a ipr egr delete, so I can't comment on that review.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #5 of 55 Old 01-12-2013, 08:13 AM Thread Starter
I win....
cRaZy8's Avatar
Quoted: 47 Post(s)
Garage
Maybe Im just being nit-picky.
I am used to the marine industry standard hose clamps.
Stainless, smooth edges that dont cut into the hose, and a substantial screw/clamp.
My only problem with the bracket for the housing is that after its mounted, you can tap on the housing and watch the bracket flex. Yes the fender is thinner, but the fender is fully boxed, and is not hanging sideways with no support.
Maybe you have your harness' routed differently, but both my truck and my brother in laws (both 2005) have their Engine Main & FICM harness' routed under the turbo outlets.
Maybe it was too much to ask for a photocopy of the directions in the box? Yes, Vince answered the phone when my brother in law called, but it took three separate calls over an hour to get to him. Wasted both peoples time.
This review was in no way trying to butcher IPR.
I am just stating facts.
I think for the price charged for the EGR delete, it was no where near complete.
I think the overall idea behind the coolant filter is great. I am actually considering changing over from my Diesel Site filter to this one. I will change out the hoses/clamps, and probably weld a gusset onto the bracket.
S362 68/.91
Irate SS T4
Holders 175/30
BPD FICM
BPD Cooler
BPD WP
ARP
Yukon Locker
4.30's
ODP St3 Manifold
NL CAI
Rudy's Intake elbow
PSP Coolant Tank
EGR Del.
Edge CTS2
SCT X3
FICM Tune
Fuel PSI Gauge
35x18's
Bilstein 2.5"
Trac. Bars
DC Power
Powerstops
USCG 50GT MMC
cRaZy8 is offline
post #6 of 55 Old 01-12-2013, 08:20 AM
Quoted: 10 Post(s)
I'm not certain there are any "motives" here. The fact of the matter this individual is disappointed with a product he received. It just so happens this company is in question about some other items so there isn't any motive there. He's provided a clear and concise reveiw.
I'm sorry but I have to call BS on this. There is no reason what so ever that any customer should have to ask for installation instructions....ever!!
You're a smart dude but I disagree with this completely.
Shack
post #7 of 55 Old 01-12-2013, 08:21 AM
I know the flex you're talking about, mine does it too. But trust me it isn't the bracket it's the inner fender moving.
post #8 of 55 Old 01-12-2013, 08:28 AM
Maybe there wasn't any motive, if not I apologize, just with what has been going on lately and the way it read it seem a lil atack'ish.
Personaly I think the instructions should either be atached to the emailed invoice or linked on the site. Yes ipr could improve on that.
It's just all we ever read is the ipr coolant filter and gen2 delete are the best on the market, to see such a negative review of what we all know to be the best available threw me for a loop.
/rant
post #9 of 55 Old 01-12-2013, 08:39 AM Thread Starter
I win....
cRaZy8's Avatar
Quoted: 47 Post(s)
Garage
No motives. I just call it like I see it. Yes he makes a nice product, but I think a little more effort to help finish off each kit would be great.
The coolant filter is very nice. The main theory behind the piece is on point. Just a couple things need to be changed to make it a great kit. Not just a great filter with some other parts that are lacking.
/rant
Just to be clear, this is the EGR delete I installed.
Exactly what you see in the pics is what you get.
No seals, no hoses, no clamps, nothing.
S362 68/.91
Irate SS T4
Holders 175/30
BPD FICM
BPD Cooler
BPD WP
ARP
Yukon Locker
4.30's
ODP St3 Manifold
NL CAI
Rudy's Intake elbow
PSP Coolant Tank
EGR Del.
Edge CTS2
SCT X3
FICM Tune
Fuel PSI Gauge
35x18's
Bilstein 2.5"
Trac. Bars
DC Power
Powerstops
USCG 50GT MMC
cRaZy8 is offline
post #10 of 55 Old 01-12-2013, 08:44 AM
Ok, that's not the gen2.
I think you can buy those kits with as many parts to fit your needs valve block off up pipe ect.
As far as o rings and clamps I would think you may have got a kit missing the hardware pakage I'm not sure.
I'm gettin the boy his 18 month shots now. I'll get you a pic of what I did about the floppy fender when I get home.
