Numbers lots and lots of numbers.
Ok I dont know if this has been discussed or not but i have a SCT ITSX tuner and have it set to stock right now and these are the numbers I get. Can someone please tell me what I am looking at. What Are good Numbers? What are bad numbers? What are normal Numbers.
Truck is a 2006 with a 6.0 with a erg delete. All these reading are sitting in driveway truck warm. This truck has never got better than about 11-12 mpg. ![]() first numbers are at Idle second numbers are WOT ICP Duty Cycle = .25 ------ .57 Injection control pressure= 4.0 ------ 22.0 VGT Duty Cycle= .66 ------ .35 Air Flow #/min= 17 ------ 120 Barometric Pressure in HG= 28.75 ------ 28.75 engine load= 21.95 ------ 41.16 FICM ignition volts= 13.5 ------ 14.0 FICM logic power volts= 14.0 ------ 14.0 Ficm main internal inj. pwr= 48. ------ 34. manifold absolute pressure= 100.75kpa ------ 140.0kpa turbo boost= .58kpa ------ 10.75kpa Thanks for all the help |
Ficm is taking a poop on you.
yep ficm is bad
can a goin bad ficm cause his 11-12 mpg ??
Imma hav to check my scan gauge when i git home
Can anyone tell me where to look for the rest of the numbers? I just want to know what I am looking at and what is normal for the Itsx numbers.
Ok I ordered the new 6 stage ficm from bulletproof. Now can anyone tell me what is better 48v 53v, or 58v?????? Is there any benefits to going more V's????
I run the 58v.
Wanted to see if there was a difference in performance or throttle response or anything like that.
