Turbo Oil Feed Line -AN adapter
Trying to find an oil line adapter for -4an feed line.
for the feed side of the oil cooler lid, basically the picture with a -4AN end on it.
What are you trying to do, your description isnt so clear. When I make custom feed lines, I use a 3/8 hardline to -6 female tube adapter, and then use a -6 to -4 union adapter, and then use a -4 hose end to attach the hose to the hardline.
I thought you had a threaded oil cooler cover?
If that's the line and cover you have to work with the easiest thing to do would be cut that hard line and put a compression to an fitting on it. |
I just cut the factory feed line and add this Earl's Performance AN to Tube Adapter Fittings 165006ERL - SummitRacing.com A -6 braided stainless line with -6 fitting will thread right onto the AN to tube adapter fitting. Here's a couple pics of turbo feed lines that i've made.
I need an adapter to go from the stock oil feed line to a -4AN line
I do have a threaded cover, this is for Gary. |
you don't need to weld an adapter. Just get the fitting
Why do you want to go -4 and not -6?
I don't want 4 over 6, I just assumed the wrong size.
ok guys I figured out what is needed thanks for the help... me and ejg3855 have had a hell of a time in the last 24 hours ordering parts for each other trading vgt and non vgt setups since he has an 03 motor, i have an 05 motor and he also has bigger cac tube do to his aftermarket intercooler
