looney non studded vs looney studded - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 20 Old 01-07-2013, 08:44 PM Thread Starter
turbotibbo's Avatar
i am looking to hear from any one that ran the looney for non studded 6.0l then upgraded to the studded verson . is there lots more power , notice any differences in shifting ect....
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #2 of 20 Old 01-07-2013, 09:10 PM
Dirty_Stroke's Avatar
I would say it was about the same amount of power difference from a street tune to a performance tune. I noticed mid and top end was a good bit stronger.
HardcoreFx4 likes this.
05 F250 FX4 Lariat, SCT Livewire, 155cc injectors, Gryphon FICM tuner, ARP studs, MTW Stage 2 Turbo, Riff Raff boots, Warren Built trans, PMF traction bars ,4 inch straight pipe, Sinister EGR delete, S&B CAI, N-fab bars, level kit, 5% limo tint, 35 Toyos and 20s, Recon smoked everything, Harley headlights, 5k HID's, Camlocker toolbox, lots more
Dirty_Stroke is offline
post #3 of 20 Old 01-07-2013, 09:12 PM Thread Starter
turbotibbo's Avatar
that much , wow intresting , any body else make the switch
blue spring mod
6.4 banjo bolts
air raid cold air
zoodad mod
high idle mod
58 volt ficm
egr delete
post #4 of 20 Old 01-08-2013, 12:19 AM
powerstrokecrzy's Avatar
Quoted: 227 Post(s)
I thought it felt like a completely different tune. Stronger all the way through. It pulls alot harder I think, then again its supposed to. I did go straight to the track file once studded and with some tweaking on the shifting end of it, its a great daily driver.
Sent from my DROID X2 using AutoGuide.Com Free App
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #5 of 20 Old 01-08-2013, 08:35 AM
The Looney Wild Track file is a completely different tune. It is night and day difference in power over the standard looney tune. I run the track file daily also. It has about as much power difference over the looney wild as the looney wild does over the looney. Lol hope that wasn't too confusing.
post #6 of 20 Old 01-08-2013, 10:54 AM
Quoted: 2 Post(s)
As Vivian mentioned on the phone with me yesterday the regular Looney(non-studded) is approx 140 hp over stock as compared to the Looney Wild (studded) tune that is approx 190hp over stock. I would think you could feel ~50hp.
Ben
2011 F250 CCSB FX4 Lariat 6.7l Deleted, SCT Tuned
Sold-2005 F250 CCSB FX4 Lariat 6.oh Powerstroke, sitting on Goodyear Duratracs, all stock minus muffler/cat delete. ~200k miles Looney tune for last 40k
sootman73 is offline
post #7 of 20 Old 01-08-2013, 11:36 AM Thread Starter
turbotibbo's Avatar
looks like i will be upgrading in the near furture . i want the power but how safe is it for a studded truck ?
blue spring mod
6.4 banjo bolts
air raid cold air
zoodad mod
high idle mod
58 volt ficm
egr delete
post #8 of 20 Old 01-08-2013, 01:20 PM
If the stud job was done correctly with flat heads and OEM gaskets then there is nothing to worry about running the Looney Wild. Just keep an eye on fuel pressure for injectors sake.
post #9 of 20 Old 01-31-2013, 09:29 AM
jaysshortbus's Avatar
This might b a dumb question but I hear everyone on here talking about looney tunes !! Is that a programmer or ???? Were do I get this ?? I have a super chips now and thinking about an sct but now I am reallt confused! !
Jay
jaysshortbus is offline
post #10 of 20 Old 01-31-2013, 09:41 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
list of tunes and where to get them?
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
